Plugins 〉ClickHouse
ClickHouse
Official ClickHouse data source for Grafana
The ClickHouse data source plugin allows you to query and visualize ClickHouse data in Grafana.
Version compatibility
Users on Grafana v9.x and higher of Grafana can use v4.
Users on Grafana v8.x are encouraged to continue using v2.2.0 of the plugin.
* As of 2.0 this plugin will only support ad hoc filters when using ClickHouse 22.7+
Installation
For detailed instructions on how to install the plugin on Grafana Cloud or locally, please checkout the Plugin installation docs.
Configuration
ClickHouse user for the data source
Set up an ClickHouse user account with readonly permission and access to
databases and tables you want to query.
Please note that Grafana does not validate that queries are safe. Queries can contain any SQL statement.
For example, statements like ALTER TABLE system.users DELETE WHERE name='sadUser'
and DROP TABLE sadTable; would be executed.
To configure a readonly user, follow these steps:
- Create a
readonlyuser profile following the Creating Users and Roles in ClickHouse guide. - Ensure the
readonlyuser has enough permission to modify themax_execution_timesetting required by the underlying clickhouse-go client. - If you're using a public ClickHouse instance, it's not recommended to set
readonly=2in thereadonlyprofile. Instead, leavereadonly=1and set the constraint type ofmax_execution_timeto changeable_in_readonly to allow modification of this setting.
ClickHouse protocol support
The plugin supports both Native (default) and HTTP transport protocols.
This can be enabled in the configuration via the protocol configuration parameter.
Both protocols exchange data with ClickHouse using optimized native format.
Note that the default ports for HTTP/S and Native differ:
- HTTP - 8123
- HTTPS - 8443
- Native - 9000
- Native with TLS - 9440
Manual configuration via UI
Once the plugin is installed on your Grafana instance, follow these instructions to add a new ClickHouse data source, and enter configuration options.
With a configuration file
It is possible to configure data sources using configuration files with Grafana’s provisioning system. To read about how it works, refer to Provisioning Grafana data sources.
Here are some provisioning examples for this data source using basic authentication:
apiVersion: 1
datasources:
- name: ClickHouse
type: grafana-clickhouse-datasource
jsonData:
defaultDatabase: database
port: 9000
host: localhost
username: username
tlsSkipVerify: false
# tlsAuth: <bool>
# tlsAuthWithCACert: <bool>
# secure: <bool>
# dialTimeout: <seconds>
# queryTimeout: <seconds>
# protocol: <native|http>
# defaultTable: <string>
# httpHeaders:
# - name: X-Example-Header
# secure: false
# value: <string>
# - name: Authorization
# secure: true
# logs:
# defaultDatabase: <string>
# otelEnabled: <bool>
# otelVersion: <string>
# timeColumn: <string>
# ...Column: <string>
# traces:
# durationUnit: <seconds|milliseconds|microseconds|nanoseconds>
# traceIdColumn: <string>
secureJsonData:
password: password
# tlsCACert: <string>
# tlsClientCert: <string>
# tlsClientKey: <string>
# secureHttpHeaders.Authorization: <string>
Building queries
Queries can be built using the raw SQL editor or the query builder. Queries can contain macros which simplify syntax and allow for dynamic SQL generation.
Time series
Time series visualization options are selectable after adding a datetime
field type to your query. This field will be used as the timestamp. You can
select time series visualizations using the visualization options. Grafana
interprets timestamp rows without explicit time zone as UTC. Any column except
time is treated as a value column.
Multi-line time series
To create multi-line time series, the query must return at least 3 fields in the following order:
- field 1:
datetimefield with an alias oftime - field 2: value to group by
- field 3+: the metric values
For example:
SELECT log_time AS time, machine_group, avg(disk_free) AS avg_disk_free
FROM mgbench.logs1
GROUP BY machine_group, log_time
ORDER BY log_time
Tables
Table visualizations will always be available for any valid ClickHouse query.
Visualizing logs with the Logs Panel
To use the Logs panel your query must return a timestamp and string values. To default to the logs visualization in Explore mode, set the timestamp alias to log_time.
For example:
SELECT log_time AS log_time, machine_group, toString(avg(disk_free)) AS avg_disk_free
FROM logs1
ORDER BY log_time
To force rendering as logs, in absence of a log_time column, set the Format to Logs (available from 2.2.0).
Visualizing traces with the Traces Panel
Ensure your data meets the requirements of the traces panel. This applies if using the visualization or Explore view.
Set the Format to Trace when constructing the query (available from 2.2.0).
If using the Open Telemetry Collector and ClickHouse exporter, the following query produces the required column names (these are case sensitive):
SELECT
TraceId AS traceID,
SpanId AS spanID,
SpanName AS operationName,
ParentSpanId AS parentSpanID,
ServiceName AS serviceName,
Duration / 1000000 AS duration,
Timestamp AS startTime,
arrayMap(key -> map('key', key, 'value', SpanAttributes[key]), mapKeys(SpanAttributes)) AS tags,
arrayMap(key -> map('key', key, 'value', ResourceAttributes[key]), mapKeys(ResourceAttributes)) AS serviceTags,
if(StatusCode IN ('Error', 'STATUS_CODE_ERROR'), 2, 0) AS statusCode
FROM otel.otel_traces
WHERE TraceId = '61d489320c01243966700e172ab37081'
ORDER BY startTime ASC
Macros
To simplify syntax and to allow for dynamic parts, like date range filters, the query can contain macros.
Here is an example of a query with a macro that will use Grafana's time filter:
SELECT date_time, data_stuff
FROM test_data
WHERE $__timeFilter(date_time)
| Macro | Description | Output example |
| $__dateFilter(columnName) | Replaced by a conditional that filters the data (using the provided column) based on the date range of the panel | date >= toDate('2022-10-21') AND date <= toDate('2022-10-23') |
| $__timeFilter(columnName) | Replaced by a conditional that filters the data (using the provided column) based on the time range of the panel in seconds | time >= toDateTime(1415792726) AND time <= toDateTime(1447328726) |
| $__timeFilter_ms(columnName) | Replaced by a conditional that filters the data (using the provided column) based on the time range of the panel in milliseconds | time >= fromUnixTimestamp64Milli(1415792726123) AND time <= fromUnixTimestamp64Milli(1447328726456) |
| $__dateTimeFilter(dateColumn, timeColumn) | Shorthand that combines $**dateFilter() AND $**timeFilter() using separate Date and DateTime columns. | $__dateFilter(dateColumn) AND $__timeFilter(timeColumn) |
| $__fromTime | Replaced by the starting time of the range of the panel casted to DateTime | toDateTime(1415792726) |
| $__toTime | Replaced by the ending time of the range of the panel casted to DateTime | toDateTime(1447328726) |
| $__fromTime_ms | Replaced by the starting time of the range of the panel casted to DateTime64(3) | fromUnixTimestamp64Milli(1415792726123) |
| $__toTime_ms | Replaced by the ending time of the range of the panel casted to DateTime64(3) | fromUnixTimestamp64Milli(1447328726456) |
| $__interval_s | Replaced by the interval in seconds | 20 |
| $__timeInterval(columnName) | Replaced by a function calculating the interval based on window size in seconds, useful when grouping | toStartOfInterval(toDateTime(column), INTERVAL 20 second) |
| $__timeInterval_ms(columnName) | Replaced by a function calculating the interval based on window size in milliseconds, useful when grouping | toStartOfInterval(toDateTime64(column, 3), INTERVAL 20 millisecond) |
| $__conditionalAll(condition, $templateVar) | Replaced by the first parameter when the template variable in the second parameter does not select every value. Replaced by the 1=1 when the template variable selects every value. | condition or 1=1 |
The plugin also supports notation using braces {}. Use this notation when queries are needed inside parameters.
Templates and variables
To add a new ClickHouse query variable, refer to Add a query variable.
After creating a variable, you can use it in your ClickHouse queries by using Variable syntax. For more information about variables, refer to Templates and variables.
Importing dashboards for ClickHouse
Follow these instructions to import a dashboard.
You can also find available, pre-made dashboards by navigating to the data sources configuration page, selecting the ClickHouse data source and clicking on the Dashboards tab.
We distribute the following dashboards with the plugin. These are aimed at assisting with support analysis of a ClickHouse cluster and do not rely on external datasets. The querying user requires access to the system database.
- Cluster Analysis - an overview of configured clusters, merges, mutations and data replication.
- Data Analysis - an overview of current databases and tables, including their respective sizes, partitions and parts.
- Query Analysis - an analysis of queries by type, performance and resource consumption.
Ad Hoc Filters
Ad hoc filters are only supported with version 22.7+ of ClickHouse.
Ad hoc filters allow you to add key/value filters that are automatically added to all metric queries that use the specified data source, without being explicitly used in queries.
By default, Ad Hoc filters will be populated with all Tables and Columns. If
you have a default database defined in the Datasource settings, all Tables from
that database will be used to populate the filters. As this could be
slow/expensive, you can introduce a second variable to allow limiting the
Ad Hoc filters. It should be a constant type named clickhouse_adhoc_query
and can contain: a comma delimited list of databases, just one database, or a
database.table combination to show only columns for a single table.
For more information on Ad Hoc filters, check the Grafana docs
Using a query for Ad Hoc filters
The second clickhouse_adhoc_query also allows any valid ClickHouse query. The
query results will be used to populate your ad-hoc filter's selectable filters.
You may choose to hide this variable from view as it serves no further purpose.
For example, if clickhouse_adhoc_query is set to SELECT DISTINCT machine_name FROM mgbench.logs1 you would be able to select which machine
names are filtered for in the dashboard.
- Add Annotations.
- Configure and use Templates and variables.
- Add Transformations.
- Set up alerting; refer to Alerts overview.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing ClickHouse on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Data Source
Use the grafana-cli tool to install ClickHouse from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Changelog
4.12.0
Features
- Support log volume queries for the SQL editor. Note that this will only work for Grafana versions >= 12.4.0 (#1475)
- Support columns with
.in ad-hoc filters (#1481)
Fixes
- Dependency updates
4.11.4
Fixes
- Fix view logs link in Explore and Dashboards (#1462)
- Fix filter for map type LogLabels (#1456)
- Temporarily disable slow JSON suggestions function (#1468)
4.11.3
Fixes
- Fix config UI bugs (#1409) and update design (#1422)
4.11.2
Features
- Second part of redesigned ClickHouse config page (behind newClickhouseConfigPageDesign) (#1387)
Fixes
- Improved error classification to mark all ClickHouse errors as downstream errors, including errors wrapped in HTTP response bodies and multi-error chains (#1405)
4.11.1
Fixes
- All Clickhouse errors are marked as downstream errors for Grafana (#1378)
4.11.0
Features
- Merge OpenTelemetry resource/scope/log attributes into a unified Labels column in Logs (#1369)
- First part of redesigned ClickHouse config page with sidebar navigation and collapsible sections (behind newClickhouseConfigPageDesign) (#1370)
Fixes
- Fix ad-hoc filter application with templated target tables (#1241)
- Fix column sorting by formatting bytes in Grafana (#1352)
- Fix events and links not displaying correctly for table view queries (#1345)
4.10.2
Fixes
- Fix Ad-Hoc filters for variable datasources #1330
- Fix switching between SQL Editor and Query Builder #1337
- Fix large JSON objects + complex JSON types #1326
- Configuration fixes related to row limit implementation #1294
- Fix bug where switched to logs query type errored #1341
4.10.1
Fixes
- Bump grafana/plugin-actions from ff169fa386880e34ca85a49414e5a0ff84c3f7ad to b788be6746403ff9bae26d5e800794f2a5620b4c (#1286)
- Bump cspell from 9.0.2 to 9.1.1 (#1278)
4.10.0
Features
- Ad-hoc queries: Allow to filter by values inside the map (#1265)
Fixes
4.9.1
Fixes
- Error logging fix
4.9.0
Features
- Add support for the Grafana
row_limitconfiguration setting. - Add support for kind, status, instrumentation library, links, events and state data for traces (#1043, #1208)
- Cancel JSON paths query after 10s (#1206)
- SQL Editor now suggests database, table, column, and function names while typing (#1204)
- Add SQL Formatter button + shortcut for making long queries more readable in the editor (#1205)
Fixes
- Fixed "run query" shortcut from running stale query (#1205)
4.8.2
Fixes
4.8.1
Fixes
4.8.0
Features
- Enable CtrlCmd + Enter keyboard shortcut to Run Query (#1158)
Fixes
- Refactor
MutateResponsefunction and PDC dialler creation (#1155) - Refactor
clickhouse.Connectto improve context cancellation handling (#1154) - Prevent usage of failed connections and improve connection management (#1156). Please note that following this change, the following limits will be set. Although we believe these limits are reasonable, you can adjust them in the datasource settings if needed:
MaxOpenConnsto 50.MaxIdleConnsto 25.ConnMaxLifetimeto 5 minutes.
4.7.0
Features
- Add JSON column sub-paths to column selection in query builder
- Added events support in trace detail view.(https://github.com/grafana/clickhouse-datasource/pull/1128)
4.6.0
Features
- Add support for new Variant, Dynamic, and JSON types (https://github.com/grafana/clickhouse-datasource/pull/1108)
Fixes
- Optimized performance for log volumes processing using ClickHouse
multiSearchAny
4.5.1
Fixes
4.5.0
Features
- Implemented log context for log queries
- Added configuration options for log context columns
- Queries parsed from the SQL editor will now attempt to re-map columns into their correct fields for Log and Trace queries.
- Added support for IN operator in adhoc filters
Fixes
- Fixed and enhanced the logic for parsing a query back into the query builder.
4.4.0
Features
- Added "Labels" column selector to the log query builder
- Datasource OTel configuration will now set default table names for logs and traces.
Fixes
- Added warning for when
uidis missing in provisioned datasources. - Map filters in the query builder now correctly show the key instead of the column name
- Updated and fixed missing
system.dashboardsdashboard in list of dashboards - Updated the duration value in example traces dashboard to provide useful information
- Fix to display status codes from spans in trace queries (#950)
4.3.2
Fixes
- Optimized performance for types dependent on the JSON converter
4.3.1
Features
- Added preset dashboard from
system.dashboardstable
Fixes
- Fix trace start times in trace ID mode (#900)
- Fixed OTel dashboard that waa failing to import (#908)
4.3.0
Features
- Added OpenTelemetry dashboard (#884)
Fixes
- Fix support for LowCardinality strings (#857)
- Update trace queries to better handle time fields (#890)
- Dependency bumps
4.2.0
Features
- Added
$__dateTimeFilter()macro for conveniently filtering a PRIMARY KEY composed of Date and DateTime columns.
4.1.0
Features
- Added the ability to define column alias tables in the config, which simplifies query syntax for tables with a known schema.
4.0.8
Fixes
- Fixed
INoperator escaping the entire string (specifically withNullable(String)), also addedFixedString(N)(#830) - Fixed query builder filter editor on alert rules page (#828)
4.0.7
- Upgrade dependencies
4.0.6
Fixes
- Add support for configuring proxy options from context rather than environment variables (supported by updating
sqlds) (#799)
4.0.5
Fixes
- Fixed converter regex for
Nullable(IP)andNullable(String). It won't match toArray(Nullable(IP))orArray(Nullable(String))any more. (#783) - Updated
grafana-plugin-sdk-goto fix a PDC issue. More details here (#790)
4.0.4
Fixes
- Changed trace timestamp table from the constant
otel_traces_trace_id_tsto a suffix_trace_id_tsapplied to the current table name.
4.0.3
Features
- Added
$__fromTime_msmacro that represents the dashboard "from" time in milliseconds using aDateTime64(3) - Added
$__toTime_msmacro that represents the dashboard "to" time in milliseconds using aDateTime64(3) - Added
$__timeFilter_msmacro that usesDateTime64(3)for millisecond precision time filtering - Re-added query type selector in dashboard view. This was only visible in explore view, but somehow it affects dashboard view, and so it has been re-added. (#730)
- When OTel is enabled, Trace ID queries now use a skip index to optimize exact ID lookups on large trace datasets (#724)
Fixes
- Fixed performance issues caused by
$__timeFilterusing aDateTime64(3)instead ofDateTime(#699) - Fixed trace queries from rounding span durations under 1ms to
0(#720) - Fixed AST error when including Grafana macros/variables in SQL (#714)
- Fixed empty builder options when switching from SQL Editor back to Query Editor
- Fix SQL Generator including "undefined" in
FROMwhen database isn't defined - Allow adding spaces in multi filters (such as
WHERE .. IN) - Fixed missing
ANDkeyword when adding a filter to a Trace ID query
4.0.2
Fixes
- Fixed migration script not running when opening an existing v3 config
4.0.1
Fixes
- Set
protocoltonativeby default in config view. Fixes the "default port" description.
4.0.0
Features
Version 4.0.0 contains major revisions to the query builder and datasource configuration settings.
Query Builder
- Completely rebuilt query builder to have specialized editors for Table, Logs, Time Series, and Traces.
- Completely rebuilt SQL generator to support more complicated and dynamic queries.
- Updated query builder options structure to be clearer and support more complex queries.
- Updated database/table selector to be in a more convenient location. Database and table options are automatically selected on initial load.
- Upgraded query builder state management so queries stay consistent when saving/editing/sharing queries.
- Separated Table and Time Series query builders. Table view operates as a catch-all for queries that don't fit the other query types.
- Combined "format" into the query type switcher for simplicity. The query tab now changes the builder view and the display format when on the Explore page. This includes the raw SQL editor.
- Added an OTEL switch for logs and trace views. This will allow for quicker query building for those using the OTEL exporter for ClickHouse.
- Updated Time Series query builder with dedicated Time column. Default filters are added on-load.
- Added an
IS ANYTHINGfilter that acts as a placeholder for easily editing later (useful for query templates/bookmarks on the Explore page.) - Added better support for Map types on the Filter editor.
- LIMIT editor can now be set to 0 to be excluded from the query.
- Table and Time Series views now have a simple / aggregate mode, depending on the query complexity.
- Updated the logs histogram query to use the new query builder options and column hints.
- Added Logs query builder with dedicated Time, Level, and Message columns. Includes OTEL switch for automatically loading OTEL schema columns. Default filters are added on-load.
- Added Trace query builder with dedicated trace columns. Includes OTEL switch for automatically loading OTEL schema columns. Default filters are added on-load.
- Updated data panel filtering to append filters with column hints. Visible in logs view when filtering by a specific level. Instead of referencing a column by name, it will use its hint.
- Order By now lists aggregates by their full name + alias.
- Order By column allows for custom value to be typed in.
- Aggregate column name allows for custom value to be typed in.
- Filter editor allows for custom column names to be typed in.
- Increased width of filter value text input.
- Columns with the
Map*type now show a[]at the end to indicate they are complex types. For example,SpanAttributes[]. - Filter editor now has a dedicated field for map key. You can now select a map column and its key separately. For example,
SpanAttributes['key']. - Map types now load a sample of options when editing the
keyfor the map. This doesn't include all unique values, but for most datasets it should be a convenience. - Added column hints, which offers better linking across query components when working with columns and filters. For example, a filter can be added for the
Timecolumn, even without knowing what the time column name is yet. This enables better SQL generation that is "aware" of a column's intended use.
Plugin Backend
- Added migration logic for
v3configs going tov4+. This is applied when the config is loaded when building a database connection. $__timeFilter,$__fromTime, and$__toTimemacros now convert toDateTime64(3)for better server-side type conversion. Also enables millisecond precision time range filtering.
Datasource Configuration
- Added migration script for
v3.xconfigurations tov4+. This runs automatically when opening/saving the datasource configuration. - Renamed config value
servertohost. - Renamed config value
timeoutto the more specificdial_timeout. - Updated labeling for port selection. The default port will now change depending on native/http and secure/unsecure setting.
- Rearranged fields and sections to flow better for initial setup of a new datasource.
- Added plugin version to config data for easier config version migrations in the future.
- Added fields for setting default values for database/table.
- Added section for setting default log database/table/columns. Includes OTEL. These are used when using the log query builder.
- Added section for setting default trace database/table/columns. Includes OTEL. These are used when using the trace query builder.
- Added OTEL switches for logs/traces for quicker query building. OTEL defaults to the latest version, and will auto update if kept on this setting.
- Increased width of inputs for typically long values (server URL, path, etc.)
- Allow adding custom HTTP headers with either plain text or secure credentials. #633
- Add
pathsetting to specify an additional URL path when using the HTTP protocol. #512
Fixes
- Queries will now remain consistent when reloading/editing a previously saved query.
- Fixed default Ad-Hoc filters. #650
- Fixed Ad-Hoc filters parsing numeric fields. #629
- Fixed majority of usability quirks with redesigned query builder.
Upgrades
- Updated all dependencies to latest compatible versions (Includes Dependabot PRs)
3.3.0
Features
- Support Point geo data type.
Fixes
- Fix timeInterval_ms macro.
- Fix Table summary and Parts over time panels in Data Analysis dashboard.
Upgrades
- Upgrade grafana-plugin-sdk-go.
3.2.0
Features
- Add
timeInterval_msmacro to allow higher precision queries on DateTime64 columns. #462.
Fixes
- Ensure databases, tables, and columns are escaped correctly. #460.
- Fix conditionAll handling. #459.
- Fix support for ad-hoc regexp filters:
=~,!~#414. - Do not create malformed adhoc filters #451. invalid values will be ignored.
- Fix auto formatting by reverting to table correctly. #469.
- Fix parsing of numeric configuration values in
yamlfile. #456.
3.1.0
- Stable release of v3.0.4-beta
3.0.4-beta
- Update Grafana dependencies to >=v9.0.0
- Feature - Add support for the secure socks proxy
3.0.3-beta
- Update ClickHouse driver to v2.9.2
3.0.2-beta
- Custom ClickHouse settings can be set in data source settings. Allow passing custom ClickHouse settings in datasource
- Histogram UI fixes Histogram UI fixes
- Support filter/filter out logs view actions
- Fix undefined database name by default
- Reset level and time field properly on table/database change
- Make it possible to clear the level field (so the histogram will render without grouping by level)
- Fix filter value that gets stuck in the UI
- Tracing dashboard added to default dashboards. Tracing dashboard
3.0.1-beta
- Users on v8.x of Grafana are encouraged to continue to use v2.2.0 of the plugin.
- Users of Grafana v9.x can use v3 however it is beta and may contain bugs.
3.0.0
- Feature - Logs volume histogram support
- Chore - Update clickhouse-go to v2.8.1
2.2.1
- Chore - Backend binaries compiled with latest go version 1.20.4
- Standard Golang HTTP proxy environment variables support (
HTTP_PROXY/HTTPS_PROXY/NO_PROXY). See FromEnvironment for more information. If the Grafana instance is started with one of these env variables, the driver will automatically load them now.
2.2.0
2.1.1
2.1.0
- Fix - Quote table names with dots by @slvrtrn in https://github.com/grafana/clickhouse-datasource/pull/298
- Add a predefined TimeRange filter if there is at least one DateTime* column by @slvrtrn in https://github.com/grafana/clickhouse-datasource/pull/304
2.0.7
- Fix - Empty template variables used with the conditionalAll macro work the same as selecting All. Allow empty Inputs for $__conditionalAll
- Fix - Intervals are limited to 1 second. limit $__interval_s to at least 1 second
- Chore - Bump ClickHouse go API to v2.5.1 Bump github.com/ClickHouse/clickhouse-go/v2 from 2.4.3 to 2.5.1
2.0.6
- Chore - Backend binaries compiled with latest go version 1.19.4
- Chore - Backend grafana dependencies updated to latest version
- Chore - Clickhouse-go client updated to v2.4.3
2.0.5
- Chore - Update sqlds to 2.3.17 which fixes complex macro queries
- Chore - Backend grafana dependency updated
- Fix - Allow default protocol toggle value when saving in settings
2.0.4
- Fix - Query builder: allow custom filter values for fields with
Maptype
2.0.3
- Chore - Backend binaries compiled with latest go version 1.19.3
2.0.2
- Feature - Update sqlds to 2.3.13 which fixes some macro queries
2.0.1
- Bug - Now works with Safari. Safari does not support regex look aheads
2.0.0
- Feature - Upgrade driver to support HTTP
- Feature - Changed how ad hoc filters work with a settings option provided in CH 22.7
- Feature - Conditional alls are now handled with a conditional all function. The function checks if the second parameter is a template var set to all, if it then replaces the function with 1=1, and if not set the function to the first parameter.
- Bug - Visual query builder can use any date type for time field
- Fix - 'any' is now an aggregation type in the visual query builder
- Fix - Time filter macros can be used in the adhoc query
- Bug - Time interval macro cannot have an interval of 0
- Fix - Update drive to v2.1.0
- Bug - Expand query button works with grafana 8.0+
- Fix - Added adhoc columns macro
1.1.2
- Bug - Add timerange to metricFindQuery
1.1.1
- Bug - Add timeout
1.1.0
- Feature - Add convention for showing logs panel in Explore
1.0.0
- Official release
0.12.7
- Fix - Ignore template vars when validating sql
0.12.6
- Fix - Time series builder - use time alias when grouping/ordering
0.12.5
- Chore - Dashboards
0.12.4
- Fix - timeseries where clause. make default db the default in visual editor
0.12.3
- Fix - When removing conditional all, check scoped vars (support repeating panels)
0.12.2
- Fix - When removing conditional all, only remove lines with variables
0.12.1
- Fix - Handle large decimals properly
0.12.0
- Feature - Time series builder: use $__timeInterval macro on time field so buckets can be adjusted from query options.
0.11.0
- Feature - Time series: Hide fields, use group by in select, use time field in group by
0.10.0
- Feature - Ad-Hoc sourced by database or table
0.9.13
- Fix - Update sdk to show streaming errors
0.9.12
- Fix - Format check after ast change
0.9.11
- Feature - $timeInterval(column) and $interval_s macros
0.9.10
- Fix - Set format when using the new Run Query button.
0.9.9
- Feature - Query Builder.
0.9.8
- Fix - Detect Multi-line time series. Handle cases with functions.
0.9.7
- Feature - Multi-line time series.
0.9.6
- Bug - Change time template variable names.
0.9.5
- Bug - Fix global template variables.
0.9.4
- Bug - Fix query type variables.
0.9.3
- Bug - Support Array data types.
0.9.2
- Bug - Fix TLS model.
0.9.1
- Feature - Add secure toggle to config editor.
0.9.0
- Initial Beta release.
