Plugins 〉Amazon Athena
Amazon Athena
Compatibility
AWS Athena datasource plugin >=3.0.0 is not compatible with Grafana versions <=10.4.x due to a breaking change in UI components.
Amazon Athena data source for Grafana
The Amazon Athena data source plugin allows you to query and visualize Amazon Athena data metrics from within Grafana.
This topic explains options, variables, querying, and other options specific to this data source. Refer to Add a data source for instructions on how to add a data source to Grafana.
Installation
If you do not have a Grafana Cloud account, you can sign up for one here.
Click on the
Install plugin
button on the Amazon Athena page on Grafana.com. This will automatically add the plugin to your Grafana instance. It might take up to 30 seconds to install.Login to your Hosted Grafana instance (go to your instances page in your profile):
https://grafana.com/orgs/<yourUserName>/instances
and the Amazon Athena data source will be installed.
Configure the data source in Grafana
To configure the Amazon Athena data source in Grafana, toggle the menu, open Connections, then click Data Sources and then either:
- If you do not have the Amazon Athena data source, click Add new data source, and then click the Amazon Athena data source.
- If you already have an Amazon Athena data source, select the one you want to configure.
Name | Description |
Name | The data source name. This is how you refer to the data source in panels and queries. |
Default | Default data source means that it will be pre-selected for new panels. |
Authentication Provider | Specify which AWS Credentials chain to use. |
Assume Role Arn (optional) | Specify the ARN of the role to assume. |
External ID (optional) | If you are assuming a role in another account, that has been created with an external ID, specify the external ID here. |
Endpoint (optional) | Optionally, specify a custom endpoint for the service. |
Default Region | Region in which the cluster is deployed. |
Data Source | Athena catalog. The list of catalogs will be retrieved automatically. |
Database | Name of the database within the catalog. |
Workgroup | Workgroup to use. |
Output Location | AWS S3 bucket to store execution outputs. If not specified, the default query result location from the Workgroup configuration will be used. Please note that if Override client-side settings is enabled in the AWS console, Output Location will be ignored. |
Authentication
Open source Grafana enables the 'AWS SDK Default', 'Credentials file', and 'Access and secret key' authentication provider methods by default. Grafana Cloud enables 'Access and secret' by default. See select an authentication method for more details.
For more information about authentication options and configuration details, see AWS authentication topic.
IAM policies
Grafana needs permissions granted via IAM to be able to read Amazon Athena metrics. You can attach these permissions to IAM roles and utilize Grafana's built-in support for assuming roles. Note that you will need to configure the required policy before adding the data source to Grafana.
Depending on the source of the data you'd query with Amazon Athena, you may need different permissions. AWS provides some predefined policies that you can check here.
This is an example of a minimal policy you can use to query Amazon Athena. It is based on the AmazonAthenaFullAccess
policy, without write permissions when possible, since Grafana should be used as read-only:
NOTE: Update the ARN of the S3 bucket if you are using a custom one.
"Version": "2012-10-17",
"Statement": [
"Sid": "AthenaQueryAccess",
"Effect": "Allow",
"Action": [
"athena:ListDatabases",
"athena:ListDataCatalogs",
"athena:ListWorkGroups",
"athena:GetDatabase",
"athena:GetDataCatalog",
"athena:GetQueryExecution",
"athena:GetQueryResults",
"athena:GetTableMetadata",
"athena:GetWorkGroup",
"athena:ListTableMetadata",
"athena:StartQueryExecution",
"athena:StopQueryExecution"
"Resource": ["*"]
"Sid": "GlueReadAccess",
"Effect": "Allow",
"Action": [
"glue:GetDatabase",
"glue:GetDatabases",
"glue:GetTable",
"glue:GetTables",
"glue:GetPartition",
"glue:GetPartitions",
"glue:BatchGetPartition"
"Resource": ["*"]
"Sid": "AthenaS3Access",
"Effect": "Allow",
"Action": [
"s3:GetBucketLocation",
"s3:GetObject",
"s3:ListBucket",
"s3:ListBucketMultipartUploads",
"s3:ListMultipartUploadParts",
"s3:AbortMultipartUpload",
"s3:PutObject"
"Resource": ["arn:aws:s3:::aws-athena-query-results-*"]
"Sid": "AthenaExamplesS3Access",
"Effect": "Allow",
"Action": ["s3:GetObject", "s3:ListBucket"],
"Resource": ["arn:aws:s3:::athena-examples*"]
Query Amazon Athena data
The provided query editor is a standard SQL query editor. Grafana includes some macros to help with writing more complex time-series queries.
Macros
Macro | Description | Example | Output example |
$__dateFilter(column) | $__dateFilter creates a conditional that filters the data (using column ) based on the date range of the panel. | $__dateFilter(my_date) | my_date BETWEEN date '2017-07-18' AND date '2017-07-18' |
$__parseTime(column,format) | $__parseTime cast a varchar as a timestamp with the given format. | $__parseTime(eventtime, 'yyyy-MM-dd''T''HH:mm:ss''Z') | parse_datetime(time,'yyyy-MM-dd''T''HH:mm:ss''Z') |
$__timeFilter(column,format) | $__timeFilter creates a conditional that filters the data (using column ) based on the time range of the panel. The second argument is used to optionally parse the column from a varchar to a timestamp with a specific format. Keep in mind that this macro uses Presto's Java Date Functions parse_datetime(string, format) when a custom format is passed as format argument. | 1. Without specifying a format: $__timeFilter(time) 2. Using the default format: $__timeFilter(time, 'yyyy-MM-dd HH:mm:ss') 3. With another custom format: $__timeFilter(time, 'yyyy-MM-dd''T''HH:mm:ss''+0000') | 1. Without specifying a format: time BETWEEN TIMESTAMP '2017-07-18 11:15:52' AND TIMESTAMP '2017-07-18 11:25:52' 2. Using the default format: TIMESTAMP time BETWEEN TIMESTAMP '2017-07-18T11:15:52Z' AND TIMESTAMP '2017-07-18T11:15:52Z' 3. With another custom format: parse_datetime(time,'yyyy-MM-dd''T''HH:mm:ss''+0000') BETWEEN TIMESTAMP '2017-07-18 11:15:52' AND TIMESTAMP '2017-07-18 11:25:52' |
$__timeFrom() | $__timeFrom outputs the current starting time of the range of the panel with quotes. | $__timeFrom() | TIMESTAMP '2017-07-18 11:15:52' |
$__rawTimeFrom() | $__rawTimeFrom outputs the current starting time of the range of the panel formatted as a string. An optional argument is used to specify the output format of the string using Joda's DateTime format. | 1. Without specifying a format: $__rawTimeFrom() 2. Using the default format: $__rawTimeFrom('yyyy-MM-dd HH:mm:ss') 3. With a custom format: $__rawTimeFrom('yyyy/MM/dd/HH) | 1. Without specifying a format: '2022-03-24 21:19:03' 2. Using the default format: '2022-03-24 21:19:03' 3. With another custom format: '2022/03/24/21' |
$__timeTo() | $__timeTo outputs the current ending time of the range of the panel with quotes. | $__timeTo() | TIMESTAMP '2017-07-18 11:15:52' |
$__rawTimeTo() | $__rawTimeTo outputs the current ending time of the range of the panel formatted as a string. An optional argument is used to specify the output format of the string using Joda's DateTime format. | 1. Without specifying a format: $__rawTimeTo() 2. Using the default format: $__rawTimeTo('yyyy-MM-dd HH:mm:ss') 3. With a custom format: $__rawTimeTo('yyyy/MM/dd/HH) | 1. Without specifying a format: '2022-03-24 21:19:03' 2. Using the default format: '2022-03-24 21:19:03' 3. With another custom format: '2022/03/24/21' |
$__timeGroup(column, '1m', format) | $__timeGroup groups timestamps so that there is only 1 point for every period on the graph. The third argument is used to optionally parse the column from a varchar to a timestamp with a specific format. | $__timeGroup(time,'5m','yyyy-MM-dd''T''HH:mm:ss.SSSSSS''Z') | FROM_UNIXTIME(FLOOR(TO_UNIXTIME(parse_datetime(time,'yyyy-MM-dd''T''HH:mm:ss.SSSSSS''Z'))/300)*300) |
$__unixEpochFilter(column) | $__unixEpochFilter achieves the same than $__timeFilter but when the time is a UNIX timestamp. | $__unixEpochFilter(time) | time BETWEEN 1637228322 AND 1637232700 |
$__unixEpochGroup(column, '1m') | $__unixEpochGroup achieves the same than $__timeGroup but when the time is a UNIX timestamp. | $__unixEpochGroup(time, '5m') | FROM_UNIXTIME(FLOOR(time/300)*300) |
$__table | $__table returns the table selected in the Table selector. | $__table | my_table |
$__column | $__column returns the column selected in the Column selector (it requires a table). | $__column | col1 |
Table visualization
Most queries in Amazon Athena are best represented by a table visualization. Any query will display data in a table, and any query that returns results will display data in a table.
This example returns results for a table visualization:
SELECT {column_1}, {column_2} FROM {table};
Time series and graph visualizations
For time series ad graph visualizations, you must:
- Select a column with a
date
ordatetime
type. Thedate
column must be in ascending order (usingORDER BY column ASC
). - Also select a numeric column.
Inspecting the query
Grafana supports macros that Amazon Athena does not, which means a query might not work when copied and pasted directly into Amazon Athena. To view the full interpolated query which works directly in Amazon Athena, click the Query Inspector button. The full query is displayed under the Query tab.
Templates and variables
To add a new Amazon Athena query variable, refer to Add a query variable.
Any value queried from an Amazon Athena table can be used as a variable.
To display a custom display name for a variable, you can use a query such as SELECT hostname AS text, id AS value FROM MyTable
. In this case, the variable value field must be a string type or cast to a string type.
After creating a variable, you can use it in your Amazon Athena queries by using Variable syntax. For more information about variables, refer to Templates and variables.
Annotations
Annotations allow you to overlay rich event information on top of graphs. You can add annotations by clicking on panels or by adding annotation queries via the Dashboard menu/Annotations view.
Example query to automatically add annotations:
SELECT
time as time,
environment as tags,
humidity as text
FROM
tableName
WHERE
$__dateFilter(time) and humidity > 95
The following table represents the values of the columns taken into account to render annotations:
time | The name of the date/time field. Could be a column with a native SQL date/time data type or epoch value. |
timeend | Optional name of the end date/time field. Could be a column with a native SQL date/time data type or epoch value. (Grafana v6.6+) |
text | Event description field. |
tags | Optional field name to use for event tags as a comma separated string. |
Provision the Amazon Athena data source
You can configure the Amazon Athena data source using configuration files with Grafana's provisioning system or using Grafana's data source JSON API . For more information, refer to the provisioning docs page.
Here are some provisioning examples.
Using AWS SDK (default)
apiVersion: 1
datasources:
- name: Athena
type: grafana-athena-datasource
jsonData:
authType: default
defaultRegion: eu-west-2
catalog: AwsDataCatalog
database: '<your athena database>'
workgroup: '<your athena workgroup>'
Using credentials' profile name (non-default)
apiVersion: 1
datasources:
name: Athena type: grafana-athena-datasource jsonData: authType: credentials defaultRegion: eu-west-2 profile: secondary catalog: AwsDataCatalog database: ‘<your athena database>’ workgroup: ‘<your athena workgroup>’
Using accessKey
and secretKey
apiVersion: 1
datasources:
name: Athena type: grafana-athena-datasource jsonData: authType: keys defaultRegion: eu-west-2 catalog: AwsDataCatalog database: ‘<your athena database>’ workgroup: ‘<your athena workgroup>’ secureJsonData: accessKey: ‘<your access key>’ secretKey: ‘<your secret key>’
Using AWS SDK default and ARN of IAM role to assume
apiVersion: 1
datasources:
- name: Athena
jsonData:
authType: default
assumeRoleArn: arn:aws:iam::123456789012:root
There are also some optional parameters to configure this datasource:
jsonData:
endpoint: https://'{service}.{region}.amazonaws.com'
externalId: '<your role external id>'
outputLocation: s3://'<your s3 bucket>'
Acknowledgment
The backend driver is based on the implementation of uber/athenadriver, which provides a fully-featured driver for Amazon Athena.
Get the most out of the plugin
- Add Annotations.
- Configure and use Templates and variables.
- Add Transformations.
- Set up alerting; refer to Alerts overview.
Async query data support
Async query data support enables an asynchronous query handling flow. Queries are handled over multiple requests (starting, checking its status, and fetching the results) instead of starting and resolving a query over a single request. This is useful for queries that can potentially run for a long time and timeout.
Async query data support is enabled by default in all Amazon Athena data sources.
Async query caching
To enable query caching for async queries, you need to be on Grafana version 10.1 or above, and to set the feature toggles useCachingService
and awsAsyncQueryCaching
to true
. You'll also need to configure query caching for the specific Amazon Athena data source.
Query result reuse
Query result reuse is a feature that allows Amazon Athena to reuse query results from previous queries. You can enable it per query by selecting the Enabled
checkbox under the Query result reuse
section in the query editor. Learn more in the Amazon Athena documentation.
{{< admonition type="note" >}} Note: Result reuse requires Amazon Athena to be on engine version 3. AWS provides instructions for Changing Amazon Athena engine versions. {{< /admonition >}}
