Plugins 〉Amazon Managed Service for Prometheus
Compatibility
Amazon Managed Service for Prometheus 2.0.0 is not compatible with Grafana<11.5.0 If you are running version 11.4.x and lower, please use plugin version 1.0.5
Amazon Managed Service for Prometheus Data Source
Amazon Managed Service for Prometheus is a Prometheus-compatible service that monitors and provides alerts on containerized applications and infrastructure at scale.
Read more about it here:
https://aws.amazon.com/prometheus/
Add the data source
- Configure this data source similar to the Prometheus data source.
- Configure AWS authentication with SigV4. Read these docs for more information on using AWS authentication in Grafana data sources. Read more about SigV4 here.
Migrate from core Prometheus to Amazon Managed Service for Prometheus
If you are using core Prometheus with SigV4 authentication, you must migrate to the Amazon Managed Service for Prometheus data source because SigV4 auth is deprecated in core Prometheus. This topic summarizes the steps required to migrate from core Prometheus to Amazon Managed Service for Prometheus.
- Get the
UIDfor Prometheus using SigV4. - Get the
UIDfor your new Amazon Managed Service for Prometheus. - Update dashboards with the new datasource
UID. - Update alert rules by exporting provisioning files and updating the data source in the model or create new alert rules.
- Recreate correlations.
- Recreate recorded queries.
Migration instructions
Get the UID for the old and new data source.
- Navigate to the configuration page for your new data source.
- Find the
UIDin the url.- Example:
“connections/datasources/edit/<DATA SOURCE UID>”
- Example:
- Copy the UID for both the old and new data sources.
"<Prom SigV4 UID>""<AMP UID>"
Dashboard migration
- Navigate to the dashboard JSON panel of your dashboard that uses the old Prometheus with SigV4 authentication.
- Click on Dashboard settings.
- Select the JSON model in the tabs.
- Search for the
"<Prom SigV4 UID>".- Example:
"uid": "<Prom SigV4 UID>" - Change both the
UIDand thetype. - The old type is
prometheus. - Example for changing
typeandUID.
"type": "prometheus", "uid": "<Prom SigV4 UID>"// can be change to
“type”: “grafana-amazonprometheus-datasource”, “uid”: “<AMP UID>”
- Example:
- Confirm the "datasource" change for all of the following categories in the JSON model.
annotationspanelstargetstemplating
- Click “Save changes” in the bottom left side of the JSON model UI.
Save your dashboard.
Alert rules migration
- Alert rule data sources cannot be changed without wiping out the query.
- There are two ways to migrate alert rules.
- First, edit the rule by exporting to a provisioned file [documentation here].
- Navigate to the Alert rules page.
- Identify the alert rule that uses the Prom SigV4 data source.
- Select “Export rule.”
- Export the rule in your choice of JSON, YAML or Terraform.
- Search the exported rule for the
"<Prom SigV4 UID>". - Change the
UIDand thetypein the exported rule.
- Rename the rule and update the
namefield in the exported rule. - Delete the old rule.
- OR second, Create a new new alert rule documentation here.
- Copy the fields from the Prom SigV4 rule.
- Create a new alert rule and select your AMP data source.
- Add the fields from the old rule to the new rule.
Correlations migration
- Create a new correlation, see documentation here.
- Identify the correlation that uses the old Prom SigV4 data source.
- Copy the fields from your correlation.
- Create a brand new correlation using the new AMP data source.
- Add the fields from the old correlation to the new correlation.
- Delete the old correlation.
Recorded queries migration
- Only available in Grafana Enterprise and Grafana Cloud.
- Create a new recorded query, see documentation here.
- Identify the recorded query that uses the old Prom SigV4 data source.
- Copy the fields from your recorded query.
- Create a brand new recorded query using the new AMP data source.
- Add the fields from the old recorded query to the new recorded query.
- Delete the old recorded query.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Amazon Managed Service for Prometheus on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Amazon Managed Service for Prometheus from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Changelog
2.3.0
- Bump aws-sdk-react to enable Grafana Assume Role in UI #491
- Chore: Move docs to docs/sources to enable publishing to website #488
- CD: Publish Github release directly, skipping draft step #486
- Update dependabot groups #479
- fix action input names #456
- Update workflows and templates #454
- Fix dependabot ignore location for npm dependencies #446
- Tweak dependabot schedule #441
- Upgrade yarn to v4.10.3 #487
- Update gitignore for yarn files #497
- Add migration notice #500
- chore(deps): update dependency @grafana/plugin-ui to v0.11.1 #509
- chore(deps): pin dependencies #508
- Publish to every environment on Cloud and Add On-Prem promotion #524
- Dependency updates:
- Bump @typescript-eslint/eslint-plugin from 8.36.0 to 8.44.1 #495
- Bump @grafana/e2e-selectors from 12.1.0 to 12.2.0 in the grafana-dependencies group #492
- Bump @testing-library/jest-dom and @types/testing-library__jest-dom #485
- Bump eslint-plugin-jsdoc from 51.4.1 to 54.1.1 #482
- Bump webpack from 5.100.2 to 5.101.3 #471
- Bump github.com/grafana/grafana-aws-sdk from 1.1.0 to 1.3.0 #490
- Bump actions/checkout from 4 to 5 #463
- Bump actions/setup-node from 4 to 5 #476
- Bump the npm-patch-dev-dependencies group with 6 updates #484
- Bump eslint from 9.31.0 to 9.35.0 #480
- Bump @grafana/plugin-ui from 0.10.8 to 0.10.9 #459
- Bump @grafana/plugin-e2e from 2.1.7 to 2.1.8 #458
- Bump @types/node from 22.15.35 to 22.16.5 #453
- Bump @grafana/plugin-ui from 0.10.7 to 0.10.8 #452
- Bump github.com/grafana/grafana-aws-sdk from 1.0.5 to 1.1.0 #449
- Bump @testing-library/dom from 10.4.0 to 10.4.1 #448
- Bump @swc/core from 1.13.0 to 1.13.3 #451
- Bump jest from 30.0.3 to 30.0.5 #447
- Bump jest and @types/jest #438
- Bump @typescript-eslint/eslint-plugin from 8.35.1 to 8.36.0 #445
- Bump @grafana/e2e-selectors from 12.1.0-250688 to 12.1.0 #443
- Bump @swc/core from 1.12.14 to 1.13.0 #444
- Bump jest-environment-jsdom from 30.0.4 to 30.0.5 #442
- Bump eslint from 9.30.1 to 9.31.0 #436
- Bump @swc/core from 1.11.29 to 1.12.14 #437
- Bump eslint-config-prettier from 10.1.5 to 10.1.8 #440
- Bump @typescript-eslint/parser from 8.35.1 to 8.36.0 #433
- Bump the grafana-dependencies group and update create-plugin #421
- Bump cspell from 9.0.2 to 9.1.3 #432
- Bump eslint-plugin-import from 2.31.0 to 2.32.0 #427
- Bump @eslint/js from 9.30.1 to 9.31.0 #423
- Bump @grafana/plugin-ui from 0.10.6 to 0.10.7 #422
- Bump @babel/core from 7.27.7 to 7.28.0 #425
- Bump @swc/jest from 0.2.38 to 0.2.39 #424
- Bump jest-environment-jsdom from 30.0.0 to 30.0.4 #418
- Bump eslint-plugin-jest from 28.11.0 to 29.0.1 #416
- Bump eslint-plugin-jsdoc from 50.6.17 to 51.4.1 #419
- Bump @grafana/plugin-e2e from 2.1.5 to 2.1.6 #417
- Bump @eslint/js from 9.35.0 to 9.36.0 #498
- Bump @types/node from 22.16.5 to 22.18.6 #499
- Bump @types/node from 22.18.6 to 22.18.8 #501
- Bump github.com/grafana/grafana-plugin-sdk-go from 0.281.0 to 0.282.0 #534
- Bump the npm-patch-dev-dependencies group with 2 updates #526
- Bump cspell from 9.1.3 to 9.2.1 #525
- Bump webpack from 5.101.3 to 5.102.1 #523
- Bump the npm-patch-dev-dependencies group across 1 directory with 4 updates #521
- Bump actions/setup-node from 5 to 6 #505
- Bump @typescript-eslint/eslint-plugin from 8.45.0 to 8.46.1 #518
- Bump the grafana-dependencies group with 6 updates #516
- Bump the npm-patch-dev-dependencies group across 1 directory with 3 updates #515
- Bump github.com/grafana/grafana-aws-sdk from 1.3.0 to 1.3.1 #514
- Bump github.com/grafana/grafana-plugin-sdk-go from 0.280.0 to 0.281.0 #506
- Bump @grafana/plugin-ui from 0.10.9 to 0.11.0 #503
2.2.1
- E2E: Use grafana selectors instead of getByText in #380
- Add support for auto-merging dependabot updates in #390
- Remove pr_commands in #393
- Bump @playwright/test from 1.52.0 to 1.53.2 #408
- Bump @types/node from 22.15.21 to 22.15.35 #407
- Bump @babel/core from 7.27.1 to 7.27.7 #402
- Bump eslint-webpack-plugin from 5.0.1 to 5.0.2 #405
- Bump @grafana/plugin-e2e from 2.1.2 to 2.1.4 #406
- Bump github.com/grafana/grafana-aws-sdk from 1.0.3 to 1.0.5 #401
- Bump glob from 11.0.2 to 11.0.3 #398
- Bump eslint from 9.30.0 to 9.30.1 #399
- Bump sass from 1.89.0 to 1.89.2 #397
- Bump @eslint/js from 9.30.0 to 9.30.1 #400
- Bump github.com/grafana/grafana-aws-sdk from 1.0.2 to 1.0.3 #395
- Bump github.com/grafana/grafana-plugin-sdk-go from 0.277.1 to 0.278.0 #394
2.2.0
- Update for new sigv4 middleware by @njvrzm in #392
2.1.1
- Republish plugin to fix hashes
2.1.0
- Dependencies: Update @grafana/prometheus and promlib with support for UTF8 metrics and labels in #339
- Chore: Migrate from Drone to Github Actions and fix e2e tests in #371
- add zizmor ignore rule in #368
- Cleanup github actions files in #367
- Migrate to plugin-ui in #343
- Chore: add label to external contributions in #340
- Bump the all-dependencies group with 34 updates and migrate to eslintconfig in #374
- Bump the all-dependencies group across 1 directory with 2 updates in #361
- Bump @babel/runtime from 7.26.0 to 7.26.10 in the npm_and_yarn group in #356
- Bump the all-dependencies group across 1 directory with 43 updates in #353
- Bump the all-dependencies group across 1 directory with 2 updates in #354
- Bump golang.org/x/net from 0.34.0 to 0.36.0 in the go_modules group in #355
- Bump github.com/grafana/grafana-plugin-sdk-go from 0.265.0 to 0.266.0 in the all-dependencies group in #350
- Bump the all-dependencies group across 1 directory with 2 updates in #345
2.0.0
- Update promlib to v0.0.7 and grafana/prometheus to 11.5.0-218678 #319
- Bump golang.org/x/net from 0.31.0 to 0.33.0 in the go_modules group #329
- Chore: Add react and react-dom major updates to dependabot ignore #331
1.0.5
- Update compatibility info in plugin.json in #327
1.0.4
- Bump cross-spawn from 7.0.3 to 7.0.6 in the npm_and_yarn group #294
- Updates github.com/grafana/grafana-aws-sdk from 0.31.3 to 0.31.4 #298
- Updates github.com/grafana/grafana-plugin-sdk-go from 0.256.0 to 0.258.0 #298
- Updates github.com/stretchr/testify from 1.9.0 to 1.10.0 #298
- Bump github.com/grafana/grafana-plugin-sdk-go from 0.258.0 to 0.260.1 in #302
- Update dependencies with create-plugin in #305
1.0.3
- Bugfix: use GetAuthSettings for env variable fallback #289
- Bump github.com/grafana/grafana-plugin-sdk-go from 0.251.0 to 0.256.0 in the all-dependencies group #283
- Bump the all-dependencies group across 1 directory with 34 updates #281
1.0.2
- Bump dependencies
- github.com/grafana/grafana-aws-sdk from v0.30.0 to v0.31.3
- github.com/grafana/grafana-plugin-sdk-go v0.241.0 to v0.251.0
- @grafana/aws-sdk from 0.3.3 to 0.5.0
- @grafana/data from 11.1.0 to 11.2.2
- @grafana/e2e-selectors from 11.1.0 to 11.2.2
- @grafana/plugin-e2e from 1.3.2 to 1.8.3
- @grafana/experimental from 1.7.11 to 2.1.1
- @grafana/tsconfig from 1.3.0 to 2.0.0
- @grafana/prometheus from 11.1.0 to 11.2.2
- @grafana/runtime from 11.1.0 to 11.2.2
- @grafana/schema from 11.1.0 to 11.2.2
- @grafana/ui from 11.1.0 to 11.2.2
- @playwright/test from 1.44.1 to 1.47.2
- @swc/core from 1.5.25 to 1.7.28
- @swc/helpers from 0.5.11 to 0.5.13
- @testing-library/dom from 10.1.0 to 10.4.0
- @types/lodash from 4.17.4 to 4.17.10
- @typescript-eslint/eslint-plugin from 6.21.0 to 7.0.0
- cspell from 6.13.3 to 8.14.4
- eslint-plugin-import from 2.29.1 to 2.31.0
- eslint-plugin-jest from 28.5.0 to 28.8.1
- eslint-plugin-jsx-a11y from 6.8.0 to 6.10.0
- eslint-plugin-react-hooks from 4.6.0 to 4.6.2
- glob from 10.3.12 to 11.0.0
- prettier from 3.3.1 to 3.3.3
- sass from 1.77.4 to 1.79.3
- tslib from 2.5.3 to 2.7.0
- webpack from 5.91.0 to 5.95.0
- Update links to documentation in the Config Editor
1.0.1
- Fix sigv4 auth in Cloud
1.0.0
- Initial public release
0.3.0
- Rename plugin & repo
0.2.0 (Private release for testing)
- Initial private release of the Amazon Managed Prometheus plugin, a wrapper around the core Prometheus datasource that uses Amazon-specific authentication.
0.1.0 (Unreleased)
Initial release.
