Plugins 〉Druid
Developer
Grafadruid
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
Druid
  • Overview
  • Installation
  • Related content
Druid as a Data Source for Grafana
Table of Contents
What is this Druid-Grafana plugin?
Grafana doesn't supports Druid as a Data Source, this plugin aims to do so.
Features
At the time of writing, the plugin supports all Grafana features and all Druid queries:
  • Druid queries: SQL, timeseries, topn, groupby, timeboundary, segmentmetadata, datasourcemetadata, scan, search, JSON
  • Variables: Grafana global variables replacement, query variables, formatter druid:json (provide support for multi-value variables within rune queries).
  • Alerts
  • Explore
  • Logs
if you're using a self-signed TLS certificate, an option to "Skip TLS verify" will be shown when "https" is used in datasource URI)
Screenshots
Datasource - Connection
Datasource - connection
Datasource - Default settings
Datasource - default settings
Panels
Panels
Query builder - JSON
Query builder - SQL
Query builder - SQL
Query builder - Timeseries
Query builder - timeseries
Query builder - Settings
Query builder - settings
Variables
Variables
Variables - Formatter - druid:json
Variables - formatter - druid:json
Explore - Logs
Explore - logs
Query builder - Settings - Logs
Query builder - settings - logs
Contribute
Any contribution is welcome! Feel free to join on Slack to discuss :) To go further, see Contribute
Install
  • From Grafana.com: grafana-cli plugins install grafadruid-druid-datasource $VERSION
    • If $VERSION is not specified latest version will be installed
  • From remote archive: grafana-cli --pluginUrl https://github.com/grafadruid/druid-grafana/releases/download/v$VERSION/grafadruid-druid-datasource-$VERSION.zip plugins install grafadruid-druid-datasource
  • From local archive: unzip grafadruid-druid-datasource-$VERSION.zip -d $YOUR_PLUGIN_DIR
Where $VERSION is for instance 1.0.0 and $YOUR_PLUGIN_DIR is for instance /var/lib/grafana/plugins
(Source: https://grafana.com/docs/grafana/latest/plugins/installation/)
Examples
You can try out various advanced features of the plugin by importing the demo dashboard and running it against the Wikipedia dataset used in the Druid quickstart tutorial.
When using the provided docker based environment (./mage env:start && ./mage), the dataset is automatically ingested in Druid, the datasource and dashboard are automatically provisionned in Grafana.
Installing Druid on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Druid from the commandline:
2. Configure the Data Source
