Plugins 〉Zendesk Datasource Plugin
Developer
Gabrielthomasjacobs
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
  • Overview
  • Installation
  • Change log
  • Related content
Zendesk Plugin
Adds Zendesk Integration
Features
  • Visualize ticket volume or details
  • Query on any field in your organization's Zendesk instance
Getting Started
First, you will need to generate an API token from the zendesk admin panel.
https://support.zendesk.com/hc/en-us/articles/4408889192858-Generating-a-new-API-token
Next, add the plugin to your Grafana instance.
In the datasource configuration page, add the API endpoint as the URL:
https://yoursubdomain.zendesk.com/api/v2/
Enable "Basic auth" and set the username to your email address followed by "/token" and the password to the API token you generated. e.g.:
username: Gabriel.Thomas.Jacobs@gmail.com/token password: footoken12345
Recommended Visualization Options:
  • visualization type: Stat
  • Calculation: Count
  • Fields: Numeric Fields
Finally, use the "Organize Fields" transform to hide unwanted fields or to re-order the fields for Table Visualizations.
Installing Zendesk Datasource Plugin on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Zendesk Datasource Plugin from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.1.2
Fix for invalid ID - Github #16
1.1.1
Add new variable 'CumulativeStatusCount' to track open/closed tickets. Simplified version target.
1.1.0
Package updates to support Grafana v10
1.0.1
Minor fixes for community submission.
1.0.0
Initial release.
