Plugins 〉Sun and Moon
Developer
Christian Fetzer
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
Sun and Moon
  • Overview
  • Installation
  • Change log
  • Related content
Build Status Coverage Status
Sun and Moon Datasource Plugin for Grafana
SunAndMoon is a Datasource Plugin for Grafana that calculates the position of Sun and Moon as well as the Moon illumination using SunCalc.
Additionally it provides annotations for sunrise, sunset, twilight, moonrise, moonset and others.
SunAndMoon
Configuration
All values are location dependent, the reference location needs to be configured in the datasource settings.
SunAndMoon Configuration
License
This projected is licensed under the terms of the MIT license.
Installing Sun and Moon on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Sun and Moon from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.
Unreleased
0.3.3 - 2024-07-09
Fixed
  • Prepare for compatibility with Grafana 12.0.
0.3.2 - 2024-06-09
Added
  • Provide maximum sun altitude value.
0.3.1 - 2024-06-08
Fixed
  • Compatibility with Grafana 11.0.
0.3.0 - 2022-11-11
Fixed
  • Noon and Midnight notifications did not show correct values for non default timezones.
  • The 'Min interval' query option was not taken into account.
Added
  • Events / annotations can be queried as metrics. This allows to visualize for example today's sunrise/sunset time on dashboards. (#20)
  • Dashboard options such as units are automatically set.
Changed
  • The annotations were migrated to the new react based plugin framework introduced in Grafana 7.2 and the plugin is no longer compatible with older versions of Grafana.
  • A single query now supports multiple metrics.
0.2.1 - 2020-11-27
Added
  • Allow per query override of location. (#35, #5)
0.2.0 - 2020-11-20
Fixed
  • Glitches in graphs caused by out of order data. (#29, grafana/#28804)
  • Annotations are no longer shown. (#31)
  • A metric is now preselected when using the datasource on a new panel.
Added
  • Location is now automatically configured.
Changed
  • The plugin was migrated to the new plugin framework introduced in Grafana 7.0 and is no longer compatible with older versions of Grafana.
0.1.6 - 2020-05-24
Fixed
  • Compatibility with Grafana 7.0.
0.1.5 - 2019-08-01
Fixed
  • Annotations were incorrectly tagged with a single tag per character (e.g. s, u, n instead of sun). (grafana/#15987)
  • Compatibility with Grafana v3.
  • Compatibility with Grafana v6.3.
0.1.4 - 2019-03-08
Added
0.1.3 - 2019-02-24
Fixed
  • Update SunCalc dependency to 1.8.0 with improved precision for moonrise/moonset calculations. (#8)
  • Update build dependencies to the latest versions. (#12)
0.1.2 - 2016-12-12
Fixed
  • Compatibility with Grafana 4.0. (#6)
0.1.1 - 2016-07-01
Fixed
  • Only the first of multiple configured annotations was displayed. (#2)
0.1.0 - 2016-06-27
Added
  • Initial version with sun and moon calculation and annotations.
