Plugins 〉Embrace
Developer
Embrace
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Application
commercial
Embrace
  • Overview
  • Installation
  • Change log
Prerequisites
Grafana ≥ 9.1.0
Embrace Metrics API Token. This can be found in the Settings page.
Embrace Mobile Grafana App
Embrace’s unified mobile observability and monitoring platform provides deep insights into your user journey to help mobile teams build better experiences. Embrace auto-collects and aggregates all of your mobile signals to produce out-of-the-box user sessions, analytics and unified dashboards that help fuel your mobile growth.
The Embrace Grafana App gives you a real-time view into your mobile app performance, including crash sessions, deployment tracking, and the overall health and trends of your mobile app. It’s an easy way to visualize and correlate Embrace dashboards alongside your existing Grafana dashboards and data sources.
Request a demo of Embrace
Embrace Free Trial
Getting Help
Documentation
Embrace
Feedback and Questions
We would love to hear what you think of this app and if you have any feature requests for future versions. Please submit any issues with the app on Github or contact us directly.
Installing Embrace on Grafana Cloud:
1. Install the Application
Use the grafana-cli tool to install Embrace from the commandline:
grafana-cli plugins install
2. Enable it
Next, log into your Grafana instance. Navigate to the Plugins section, found in your Grafana main menu.
Click the Apps tabs in the Plugins section and select the newly installed app.
To enable the app, click the Config tab. Follow the instructions provided with the application and click Enable. The app and any new UI pages are now accessible from within the main menu, as designed by the app creator.
If dashboards have been included with the application, they will attempt to be automatically installed. To view the dashboards, re-import or delete individual dashboards, click the Dashboards tab within the app page.
Changelog
1.1.0
Minor updates.
1.0.1
Minor presentation tweaks.
1.0.0
Initial release.
