Plugins 〉OData
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
OData
- Overview
- Installation
- Change log
- Related content
Grafana OData Data Source
Visualize data from OData data sources with Grafana.
About
This is a Grafana data source for showing data from OData V4 compliant data sources.
It was originally developed for internal purposes and is now made available to the open source community.
Getting started
Open Grafana and go to Configuration / Data Sources. Click Add data source
button.
Enter OData
into the filter input field and select the OData Data Source.
Provide the URL of your OData Service Root and click Save & test
to test the connection.
The URL space encoding
setting can be used to specify the encoding of spaces in URLs. Percent
uses %20
(see RFC
3986), while Plus
uses +
(used in form data). E.g. $filter=value%20EQ%201
vs. $filter=value+EQ+1
Add other connection settings, such as auth settings, as necessary.
To use the data source, create a new query and select the newly created OData data source.
Choose an entity set, an appropriate time property, and the metric you want to view. Now you should be able to see data for the selected time frame.
Related Links
- Grafana - the open source analytics & monitoring solution for many data sources
- Build a Grafana data source plugin - a tutorial that explains how to develop your own data source plugin.
- OData - the ISO/IEC approved, OASIS standard for building and using data-driven RESTful APIs
Contributing
This project is maintained by d-velop but is looking for contributors. If you consider contributing to this project please read CONTRIBUTING and DEVELOPING for details on how to get started.
License
Please read LICENSE for licensing information.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing OData on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install OData from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
[1.1.0] 2024-03-14
Features
- #2: Made time property optional
- Updated to go version
1.21
- Updated to Grafana
10.2
- Configurable space encoding (
%20
or+
[1.0.0] 2023-05-12
Features
- Initial revision
