Plugins 〉MonetDB
MonetDB
MonetDB
MonetDB datasource plugin for Grafana
The MonetDB datasource plugin allows you to connect to a MonetDB database instance, to query the data and visualize it in a grafana dashboard.
Adding the datasource
Go to home menu, then select connections. Here you will see the Datasource options. Enter "MonetDB" in the search box and add it. Then enter the connection setting for your database instance.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing MonetDB on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Data Source
Use the grafana-cli tool to install MonetDB from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Changelog
[0.0.1] (Unreleased)
Initial release.
[0.2.0]
Plugin submitted and approved
