Plugins 〉MonetDB
Developer
Dataspex
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
MonetDB
  • Overview
  • Installation
  • Change log
  • Related content
MonetDB
MonetDB datasource plugin for Grafana
The MonetDB datasource plugin allows you to connect to a MonetDB database instance, to query the data and visualize it in a grafana dashboard.
Adding the datasource
Go to home menu, then select connections. Here you will see the Datasource options. Enter "MonetDB" in the search box and add it. Then enter the connection setting for your database instance.
Installing MonetDB on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install MonetDB from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
[0.0.1] (Unreleased)
Initial release.
[0.2.0]
Plugin submitted and approved
