Plugins 〉CloudWatch Alarm
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
CloudWatch Alarm
- Overview
- Installation
- Change log
- Related content
Grafana CloudWatch Alarm data source
A data source plugin for Grafana which queries for the current state of Amazon Web Services CloudWatch alarms.
This Grafana plugin has been designed to help us to easily create a single dashboard that gives us a quick overview of all alerts/alarms from different monitoring solutions (ex: Grafana and CloudWatch).
Note that it only queries CloudWatch for the current state of alarms, it does not query for the history. As such, this data source is best used with the "table" visualization.
If you would like to create graphs based on the alarm history, it would be better to configure AWS to store the alarm state as custom metrics (the regular alarm history only goes back 14 days). For example by following this guide: Extending and exploring alarm history in Amazon CloudWatch and then using the regular CloudWatch data source that ships with Grafana.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing CloudWatch Alarm on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install CloudWatch Alarm from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
v2.0.1
- Update dependencies
- Fix inconsistency between the filter GUI and what is actually being queried, after having just added a new panel.
v2.0.0
- Add AlarmDescription field (This new field can be hidden by adding an "Hide in table" override to your panel)
v1.2.0
- Support for template variables (within the alarm name prefix and region)
v1.1.0
- Migrate grafana-toolkit to grafana plugin-tools
- Remove build instructions from readme
- Support for overriding the CloudWatch API endpoint (bgardner-noggin)
- Support for composite alarms
v1.0.1
- Change plugin id from "computest-cloudwatch-alarm-datasource" to "computest-cloudwatchalarm-datasource"
- Different logo
- Add screenshots
- Add keywords
v1.0.0
First release
