Plugins 〉CnosDB
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
CnosDB
- Overview
- Installation
- Change log
- Related content
CnosDB data source for Grafana
This document describes how to install and configure CnosDB data source plugin for Grafana, and to query and visualize data from CnosDB.
Installation
At first, you should add a Connection to query CnosDB.
Navigate to Configurations / Plugins, search cnosdb
and then click it.
Click button Create a CnosDB data source.
Configure the connection options, then click the Save & test button.
If you see "Data source is working"
that means CnosDB data source connected successfully.
Usage - Dashboard
See Use Dashboards for more instructions on how to use grafana dashboard.
Navigate to Dashboards, click New Dashboard in dropped down list, then click Add a new panel. Now you can see the visual query editor.
Visual query editor
Click the area after FROM
to choose the table.
Click the area after SELECT
to choose the column.
Now you can see the visualization of the query result.
Raw query editor
You can also enter the raw sql editor mode by clicking this button.
Now the whole visual query editor means SQL query below:
SELECT date_bin(INTERVAL '1 minute', time, TIMESTAMP '1970-01-01T00:00:00Z') AS time, avg(usage_user)
FROM cpu
WHERE $timeFilter
GROUP BY date_bin(INTERVAL '1 minute', time, TIMESTAMP '1970-01-01T00:00:00Z')
ORDER BY time ASC
You can see that SQL in raw query editor.
Save your panel
Click Apply
to save the panel, and then you will be navigated to New dashboard page.
You'll see the panel we just edited on New dashboard page.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing CnosDB on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install CnosDB from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
