Plugins 〉Finnhub
Finnhub
Data Source Grafana plugin for Finnhub.
Before starting, it's necessary to get an API token from Finnhub and paste it to the "API Token" field in the plugin settings.
Currently supported queries:
Free API
Premium API
A sample dashboard provisioning file is available at provision/dashboard.json. Read more about dashboards provisioning.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Finnhub on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Data Source
Use the grafana-cli tool to install Finnhub from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
0.6.0
- Add support for
$symbolvariable
0.5.0
- Remove @grafana/ui Form usage
- Update React to v.18
- Remove unused dependencies
0.4.1
- Remove
grafanaVersionfromplugin.json - Update
grafanaDependencyinplugin.json
0.4.0
- Update the plugin to be compatible with Grafana 10
0.3.2
- Update dependencies
0.3.1
- Restore trades endpoint (websocket)
0.3.0
- Store API token in secure field
- Temporarily disabled trades websocket endpoint due to proxy auth issue (quote query with dashboard refresh can be used as a workaround).
0.2.1
- Update the plugin to be compatible with Grafana 8
- Add social sentiment endpoint support
0.1.1
- Initial release
