Plugins 〉Trend Box
The Trend Box plugin has been deprecated and is no longer maintained.
Trend Box
Grafana Trend Box
A trend box panel for Grafana.
Overview
This panel shows the percentage change between the first and last values of a series. This is useful if you want to to monitor a value as it changes over time. The panel can also work with multiple series by adding together the values at each end. Options for this panel include variable font sizes, precision and units; a drilldown link for the entire panel; and color thresholds for the percentage change.
Compatibility
This panel should work with the following data sources: Graphite.
Development
Docker is an easy way to spin-up an instance of Grafana. With docker installed, run the following command in the directory containing the plugin; this will expose the local plugin on your machine to the Grafana container so you can test it out.
docker run -it -v $PWD:/var/lib/grafana/plugins/trend_box -p 3000:3000 --name grafana.docker grafana/grafana
Now do this...
# Install development packages
npm install
Install the grunt-cli
sudo npm install -g grunt-cli
Compile into dist/
grunt
Restart Grafana to see it
docker restart grafana.docker
Watch for changes (requires refresh)
grunt watch
Use grunt test to run the Jasmine tests for the plugin; and grunt eslint to check for style issues. Note that the plugin controller isn't tested because it depends on Grafana native libraries, which aren't available outside of Grafana.
Contributing
For bugs and new features, open an issue and we'll take a look. If you want to contribute to the plugin, you're welcome to submit a pull request - just make sure grunt runs without errors first.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Trend Box on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Trend Box from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
