Plugins 〉Tokio Console
Tokio Console
Grafana Tokio Console Data Source
This is a streaming Grafana data source which can connect to the Tokio console subscriber. It provides similar functionality to the console TUI frontend (albeit more limited at the moment!). It currently supports the 'tasks list' and 'task details' data streams.
Usage
You can create a new Tokio Console data source for each process that you want to connect to. The
Configuring the data source
Only two parameters are available for the data source:
- URL - The address of a console-enabled process to connect to. Equivalent to the
<TARGET_ADDR>argument of theconsoleTUI. - Retain for - how long to continue displaying completed tasks and dropped resources after they have been closed. Equivalent to the
--retain-forflag of theconsoleTUI.
Using the data source
The easiest way to use the data source is to import the default dashboards that come with it. To do so, navigate to the data source's settings page and click the 'Dashboards' tab, then click the 'Import' button for all available dashboards.
You can also create arbitrary visualisations of the (streaming) data using Grafana's standard panels + transforms. The recommended path to doing so is to take a look at the panels in the imported dashboards and make incremental changes to a copy of the dashboard.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Tokio Console on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Data Source
Use the grafana-cli tool to install Tokio Console from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.
Unreleased
1.0.1
Changed
- Loosened requirements on Grafana to allow the plugin to run on any version greater than 8.4.0.
1.0.0 - 2022-05-06
Initial release.
