Plugins 〉Tokio Console
Developer
Ben Sully
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
Tokio Console
  • Overview
  • Installation
  • Change log
  • Related content
Grafana Tokio Console Data Source
This is a streaming Grafana data source which can connect to the Tokio console subscriber. It provides similar functionality to the console TUI frontend (albeit more limited at the moment!). It currently supports the 'tasks list' and 'task details' data streams.
Usage
You can create a new Tokio Console data source for each process that you want to connect to. The
Configuring the data source
Only two parameters are available for the data source:
  • URL - The address of a console-enabled process to connect to. Equivalent to the <TARGET_ADDR> argument of the console TUI.
  • Retain for - how long to continue displaying completed tasks and dropped resources after they have been closed. Equivalent to the --retain-for flag of the console TUI.
Using the data source
The easiest way to use the data source is to import the default dashboards that come with it. To do so, navigate to the data source's settings page and click the 'Dashboards' tab, then click the 'Import' button for all available dashboards.
You can also create arbitrary visualisations of the (streaming) data using Grafana's standard panels + transforms. The recommended path to doing so is to take a look at the panels in the imported dashboards and make incremental changes to a copy of the dashboard.
Installing Tokio Console on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Tokio Console from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.
Unreleased
1.0.1
Changed
  • Loosened requirements on Grafana to allow the plugin to run on any version greater than 8.4.0.
1.0.0 - 2022-05-06
Initial release.
