Plugins 〉Mosaic
Developer
boazreicher
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
Mosaic
  • Overview
  • Installation
  • Change log
  • Related content
Mosaic Plot
logo
Documentation can be found here
Mosaic Plot is a Grafana panel plugin for visualizing large datasets as heatmaps
Mosaic Plot differs from existing heatmap panels by providing several additional features as well as by providing many more styling options
Besides visualizing regular heatmaps, Mosaic Plot can be used to plot regular timeseries data with high cardinalities in a very space-efficient manner
Mosaic Plot can be configured to be very compact, allowing a user to show a very large amount of data while taking up only a minimum porition of a dashboard's "real estate"
demo1 stats variations cariationa2 mandelbrot focus
pages-build-deployment
CI
Release
Installing Mosaic on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Mosaic from the commandline:
grafana-cli plugins install
Changelog
1.0.14
Fixed axis labels when using light theme (https://github.com/boazreicher/mosaic-plot/issues/3)
1.0.13
Updated data format options to support usecases with a single data frame (https://github.com/boazreicher/mosaic-plot/issues/2)
1.0.10
Added the soft-max option (https://github.com/boazreicher/mosaic-plot/issues/1)
1.0.0 (Unreleased)
Initial release.
