Plugins 〉QR code
Developer
Beta Technologies
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
QR code
  • Overview
  • Installation
  • Change log
  • Related content
QRcode
Dashboard
Overview / Introduction
Utilizing the react QR code library, this plugin takes a string and renders it as a QR code. Variable interpolation is implemented.
Requirements
Grafana >= 9.0.0
Getting Started
After adding the panel, set the value property to the string to be rendered
Package
Build
npm run build
Generate signature manifest
export GRAFANA_ACCESS_POLICY_TOKEN=<redacted - get from keypasx>
npx @grafana/sign-plugin@latest --rootUrls https://github.com/Beta-Technologies/grafana-panel-qrcode
Zip / Generate SHA1
mv dist betatech-qrcode-panel
zip betatech-qrcode-panel-1.0.0.zip betatech-qrcode-panel -r
rm -rf betatech-qrcode-panel
shasum betatech-qrcode-panel-1.0.0.zip
Push latest
git add -A
git commit -m 'new version of plugin'
git push
Validate
Run validator (save time in automated steps of approval cycle)
docker run --pull=always grafana/plugin-validator-cli https://github.com/Beta-Technologies/grafana-panel-qrcode/raw/refs/heads/main/betatech-qrcode-panel-1.0.0.zip
License
MIT License, see LICENSE.
Installing QR code on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install QR code from the commandline:
grafana-cli plugins install
Changelog
1.0.0 (2024-08-28)
Initial release. Submit to Grafana for signature
