Plugins 〉Status Panel
Status Panel
Status Panel
A simple plugin to display the state of your resource.
Overview
Status Panel is a Grafana plugin designed to visualize the status of resources in a straightforward and customizable
color card format.
The status is based on the resource's metrics or health checks queries, with severity thresholds
that can be defined by the user.
Features
- Customizable Status Cards: Display resource status using color-coded cards that reflect severity levels based on user-defined thresholds.
- Titles and Subtitles: Add titles and subtitles to each status card to clarify resource information.
- Clickable Cards with URLs: Configure a URL to open when clicking on a status card, enabling quick navigation to additional details or resources.
- Metric Display and Units: Optionally display metrics on the cards and define units for enhanced readability.
- Multiple Cards per Panel: Add queries to display multiple cards in a single panel.
- Support for Table: If query return a table (array of number field), each column is considered as a card
- Individual Card Customization: Use override fields for advanced customization of each card independently.
Compatibility
Work for with all datasources as long as it returns a number field, like Prometheus, Loki, InfluxDB ...
Screenshots
This plugin supports autoscaling for best-fit sizing and font size of each cards to the panel size.
Card variant options
Multi cards in one panel
Documentation
This panel provides some customization options and are searchable from the menu.
Options
You can customize the panel with the following options:
- Title: display the title of the card
- Subtitle: display the subtitle of the card
- URL: URL to open when clicking on the card
- (if URL) Open URL in new tab: choose if the URL should be open in a new tab
- Aggregate queries in a single card: Aggregate all queries in one card
- Corner Radius: set the corner radius of the card (with css attribute)
- Flip Card: set if card do a flip animation
- (if not Flip Card) Stay on: select the side of the card to display
- (if Flip Card) Flip interval: set the time in seconds to flip the card
- Display nothing when 'no data': if no data is returned by the query, choose if you want a card empty card marked "no data" (disable) or show nothing (enable)
String variables
For text fields (Title, Subtitle, URL), you can use string formatted variables, to make the text more dynamic.
{{query_name}}: will be replaced by the query name (A, B, C, ... by default){{query_value}}: will be replaced by the value of the query (calculate with the selected aggregation){{query_index}}: will be replaced by the index of the query (0, 1, 2, ... by default){{column_name}}: will be replaced by the column name if query return a table{{$__interval}}: will be replaced by the interval of the query{{time}}: will be replaced by the sending query time. You can specify the format with{{time format}}(see EMACS - Date Time String Format){{time DD-MM-YYYY HH:mm:ss}}: format the query time toDD-MM-YYYY HH:mm:sslike01-01-2022 00:00:00{{time HH:mm:ss}}: format the query time toHH:mm:sslike12:14:36
{{metric_name}}: (for Prometheus) will be replaced by the metric name{{label:<label_name>}}: (for Prometheus) get the value of the label by his name. Must be present in the query expression
You can add multiple variables in the same field, like {{query_name}} - {{query_value}}
Display options
You can customize the apparence of the text with the following options:
- Aggregation: Calculate method of the query value, used for threshold calculation
- Last: (default) get the last value of the time range, returned by the query
- First: get the first value of the time range, returned by the query
- Max: get the maximum value of the time range, returned by the query
- Min: get the minimum value of the time range, returned by the query
- Sum: get the sum of the values of the time range, returned by the query
- Avg: get the average of the values of the time range, returned by the query
- Count: get the number of values of the time range, returned by the query
- Delta: get the difference between the first and the last value of the time range, returned by the query
- Display value metric: show the value of the query on the card
- Metric font format: set the style of the metric text (bold, italic, underline, ...)
- Metric Unit: set the unit of the metric value (like
ms,B,Gbits/s, ...)
Thresholds
You can define thresholds to change the color and the severity depending on the query value by selected aggregation.
Thresholds are calculated if the query value is greater or equal to the threshold value.
example:
query_value = 10
threshold_1 = 1
threshold_2 = 5
threshold_3 = 15
threshold_4 = 20
Oredered thresholds descending from the highest to the lowest
if query_value >= threshold_4:
select_threshold = threshold_4
elif query_value >= threhold_3:
select_threshold = threshold_3
elif query_value >= threshold_2:
select_threshold = threshold_2 # <= in this example, this is the selected threshold
elif query_value >= threshold_1:
select_threshold = threshold_1
else:
select_threshold = default
Explication
threshold_3 > query_value >= threshold_2
Thresholds are defined by the following options:
- color: set the color of the card, with the color picker
- severity: text to display on the card, when the threshold is reached
- value: value of the threshold (only number)
Overridden fields
If you want to customize the card individually, you can use the overridden fields.
- Title
- Subtitle
- URL
- Open URL in new tab
- Aggregation
- Metric Unit
- Thresholds
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Status Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Status Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
v1.1.1
Changed
- Fix no values of formattedVariables
metric_nameandlabelon Prometheus Datasource. #18
v1.1.0
Added
- Support for multi number type fields in query result (table)
- When a query return a table, each number field are considered as a card (multi cards).
- For each number field, Thresholds are computed.
- If "Aggregate Queries in single card" is enabled, all number fields from all queries, computer their own Threshold and the higher Threshold (by his value) is used for display title, metrics, severity ...
- New formatted string
{{column_name}}to show the column name when query return a table (propnameof field). - New component
FlipCardNoDatato show "no data" like aFlipCardbut without threshold background color and severity
Changed
- Move getting values from query on-top level
StatusPanelcomponent instead inFlipCard. MakingFlipCardagnostic and just accept aggregate query value in props. - Move formatted string compilation logic from
FlipCardtoCardWrapper(above) to makeFlipCardstring agnostic and just pass compiled string to props. - Change "Use 'Disable' color if no data" (option
isGrayOnNoData) toggle switch to "Display nothing when 'no data'" ( optionisNothingOnNoData) for display or not "no data" text instead of a card (or show nothing) - Change how formatted string "labels" variables are getting. Now get labels from prop
labelsof the returned field. - [Performance improvement] Change how
FlipButtonis displaying by using CSS property instead ofuseHoverhook. This change, reduce the number of times theStatusPanelcomponent update and performance is improved. - Change plugin fqdn in demo dashboard after first release on store.
Removed
- [Legacy] remove
useEventListenerhooks. Not used - [Legacy] remove
useHoverhook. No longer used now
v1.0.1
Changed
- Update LICENSE and NOTICE files to change code owner and mention the original code owner (Grafana Labs)
- Upgrade
package.jsondependencies to use Grafana10.4.0 - Fix tests e2e according to the package upgrade
v1.0.0
Breaking Changes
Make this plugin more simple and easy to use.
The plugin now only supports the number type of data. The plugin will not work with other types of data.
Added
- Customizable thresholds (Severity color, Severity text, Value threshold). like the threshold editor of Grafana default option
- Select metric unit to be displayed (like the unit selector of Grafana default option)
- Panel subtitle (to display a metric category or whatever you want)
- Panel title and subtitle can be formatted with formatted variables (like Query name
{{query_name}}, Query value aggregate{{query_value}}...). - Tests End-to-End
- CI/CD pipelines
Changed
- Fix the bug of non save panel flip state, by adding an option to save the flip state
- Multi panes in one panel
- Each pane corresponds to a Query
- Each pane share the same thresholds, unit, and title and subtitle
- Panes are in grid layout (flexbox).
- Panes size (height and width, and font size) are responsive according to the panel size
Removed
- Defined weird thresholds
- Alert system
- Auto scroll feature
- Annotation display mode
- Things that make this plugin not simple to use.
