Plugins 〉Axiom
Developer
Axiom, Inc.
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
commercial
Axiom
  • Overview
  • Installation
  • Change log
  • Related content
Instantly visualize Axiom data in Grafana
The Grafana data source plugin is the easiest way to query event data from Axiom directly in Grafana dashboards.
Requirements
This plugin has the following requirements:
Configuration
  1. Add a new data source in Grafana
  2. Select the Axiom data source plugin
  3. Enter your Axiom advanced API token
  4. Save and test the data source
Visualizing data
The Axiom data source plugin provides a custom editor to query and visualize event data from Axiom.
  1. Create a new panel in Grafana
  3. Use the query editor to filter, transform and analyze your data
Installation
Installation on Grafana Cloud
Installation with Grafana CLI
grafana-cli plugins install axiomhq-axiom-datasource
Installation with Docker
  1. Add the plugin to your docker-compose.yml or Dockerfile
  2. Set the environment variable GF_INSTALL_PLUGINS to include the plugin
GF_INSTALL_PLUGINS="axiomhq-axiom-datasource"
Installing Axiom on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Axiom from the commandline:
2. Configure the Data Source
Changelog
0.5.1
  • fix(repeat panels): use scopedVars for query by @schehata in #69
0.5.0
  • feat: bump frontend-workers/apl by @kevinehosford in #64
  • fix(monaco): update hash and re-add copy step by @kevinehosford in #67
  • use tabular-row format by @schehata in #66
  • Bump fast-loops from 1.1.3 to 1.1.4 by @dependabot in #65
  • Bump micromatch from 4.0.5 to 4.0.8 by @dependabot in #68
  • Bump braces from 3.0.2 to 3.0.3 by @dependabot in #63
0.4.0
  • Added support for advanced API tokens by @schehata (#59)
  • Deprecate usage of Personal Tokens by @schehata (#59)
  • Upgraded axiom-go to version v0.17.8
0.3.1
  • Show the URL config field in plugin settings by @schehata in #58
0.3.0
  • fix: Run queries concurrently to speed up panels with many queries by @jahands in #40
  • testing: provide a datasource & dashboard for quick testing by @schehata in #57
0.2.0
  • feat: replace plugin screenshots by @dominicchapman in #29
  • Add placeholder, query shortcut to QueryEditor by @bahlo in #30
  • Fix totals switch when submitting via keybinding by @bahlo in #31
  • Fix history bugs by @bahlo in #32
0.1.9
  • switch to using call resource functionality by @mschoch in #23
  • handle totals table groups same as series by @mschoch in #24
  • fix: mismatch between values and fields arrays and longToWide on … by @a-khaledf in #21
  • docs: update README by @dominicchapman in #25
  • feat: revise Axiom logo for light background by @dominicchapman in #26
  • fix handling of fields with escaped dots by @mschoch in #28
