Plugins 〉Waterfall Panel
Waterfall Panel
Waterfall panel
This panel is intended to visualize a single time series as a waterfall panel, e.g. to show dependencies between jobs running in parallel in a build pipeline, or a series of HTTP requests.
Configuration
After installation, you can add a new panel type "Waterfall Panel" to your dashboards.
Expected fields
The panel can only handle a single time series, and the time series can consist of these fields:
| field type | required | description |
| time | yes | starting point |
| number | yes | duration in seconds |
| string | no | name |
Make sure you select the fields of the time series as a "Table"!
The time frame will be calculated automatically and creates the panel frame. Each tuple will be represented by a bar in the panel, starting at its "starting point" and taking up space relative to its "duration".
Display configuration
- "Show inline bar labels" will show the labels inside the bars. The labels are populated from the string field.
- "Show duration in bar labels" will show the duration in seconds inside the bars.
- "Bar color" is for changing the color of the bars.
- "Value Time Units" is currently hardcoded to "seconds", but will be expanded in future versions.
Development
Please refer to the development guide.
Credits
- Icon made from Icon Fonts is licensed by CC BY 3.0
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Waterfall Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Waterfall Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
