Plugins 〉GCP Status
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
GCP Status
- Overview
- Installation
- Change log
- Related content
Google Cloud Platform Status data source for Grafana
Introduction
The Google Cloud Platform Status data source is a plugin for Grafana that retrieves GCP Service Statuses from the following URL:
https://status.cloud.google.com/incidents.json
and allows visualizing them in a log format.
Requirements
- Grafana log visualization
Highlights
- Works Log visualization panel.
- Visualize incident logs in order of the timeline.
- Filter entries based on the selected Time Range or Service Name or Location.
License
Apache License Version 2.0, see LICENSE.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing GCP Status on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install GCP Status from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
0.1.0
Initial release.
