Plugins 〉Anodot
Developer
Anodot
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
commercial
Anodot
  • Overview
  • Installation
  • Change log
  • Related content
Anodot Panel Plugin
This is Anodot Panel Plugin for Grafana, which together with Anodot Datasource Plugin allows users to use Anodot data for building Grafana Dashboards. The Anodot Panel plugin supports several scenarios for displaying Anodot data from your account. The full documentation for using it can be found here.
Please note - You need an active Anodot account in order to use this plugin.
What is a Grafana Panel Plugin?
Panels are the building blocks of Grafana. They allow you to visualize data in different ways. While Grafana has several types of panels already built-in, you can also build your own panel, to add support for other visualizations.
For more information about panels, refer to the documentation on Panels
Installation
You can get the Anodot Panel Plugin in these ways:
  1. Clone this github repository, build the plugin and deploy it to your grafana deployment.
  2. Unzip zip archive from this repository to your grafana-plugins folder.
  3. Get it from the Grafana plugins library
  4. Use grafana-cli for installation
Installing/Updating with grafana-cli
grafana-cli plugins install anodot-panel
grafana-cli plugins update anodot-panel
See more details here.
Getting started
  1. Install dependencies
yarn install
  1. Build plugin in development mode or run in watch mode
yarn dev
yarn watch
  1. Build plugin in production mode
yarn build
Installing Anodot on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Anodot from the commandline:
Change Log
All notable changes to this project will be documented in this file.
v1.0.0
Initial Release
