Plugins 〉Anodot Datasource
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Anodot Datasource
- Overview
- Installation
- Related content
Grafana Data Source Plugin
This is Anodot Datasource Plugin for Grafana, which together with the Anodot Panel Plugin allows users to use Anodot data for building Grafana Dashboards.
Using the Anodot Data Source Plugin
You can get the Anodot Data Source Plugin in these ways:
- Clone this github repository, build the plugin and deploy it to your grafana deployment.
- Unzip zip archive from this repository to your grafana-plugins folder.
- Get it from the Grafana plugins library
- Use grafana-cli for installation
Setting up the Anodot Data Source
Once you have the plugin installed, please follow the steps below to configure it for use:
- You will need to set up an API token. Click here to find out how to get an Anodot Access Key. Click here to learn how to obtain an access key from Anodot.
- You will need to set up your Anodot URL. For most customers - that URL is 'app.anodot.com'. You can find your URL when you log in to Anodot.
- Once you've set these two parameters - simply hit the "Save & Test" and you are good to go.
What is Grafana Data Source Plugin?
Grafana supports a wide range of data sources, including Prometheus, MySQL, and even Datadog. There’s a good chance you can already visualize metrics from the systems you have set up. In some cases, though, you already have an in-house metrics solution that you’d like to add to your Grafana dashboards. Grafana Data Source Plugins enables integrating such solutions with Grafana.
- Grafana documentation
- Grafana Tutorials - Grafana Tutorials are step-by-step guides that help you make the most of Grafana
- Grafana UI Library - UI components to help you build interfaces using Grafana Design System
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Anodot Datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Anodot Datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
