Plugins 〉Aggregations.io
Developer
Aggregations.io
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
commercial
Aggregations.io
  • Overview
  • Installation
  • Change log
  • Related content
logo Aggregations.io
Real Time Monitoring Using Your Analytics Data
charts
Before You Begin
Ensure you've created an account & Api key for Aggregations.io
Check out the full docs
Easy Setup
filter-setup
Features
  • Alerting
  • Variables & Filters
  • Repeated Panels
  • Long (tabular) Data Option
  • Label Controls
  • Data Reaggregation/Rollups
Any Questions?
Let us know! Feel free to email help@aggregations.io
Installing Aggregations.io on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Aggregations.io from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.1.1
  • 🎉 Added support for Recalculate Intervals option, enabling rollups based on the grafana Query Options time periods.
  • 🐛 Bug fix for Incomplete Intervals option not visible when ungrouped Filter was selected
1.1.0
  • Initial release.
