Plugins 〉Plotly panel
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Plotly panel
- Overview
- Installation
- Related content
Plotly Panel
https://github.com/ae3e/ae3e-plotly-panel
Render any kind of charts from any datasource with Plotly (An open source javascript graphing library)
Unlike the natel-plotly-panel, this plugin is not limited to specific types of charts. But, on the other hand, the user interface is really rough in order to let users to set all options available in Plotly.
The Data, Layout and Config fields match the common parameters described in Plotly's documentation. They must be in JSON format.
Data provided by the datasource can be transformed via a user-defined script before to be injected in the Plotly chart. The script includes 2 arguments :
data
: Data returns by the datasourcevariables
: Object that contains Grafana's variables available in the current dashboard (user variables and few global variables :__from
,__to
,__interval
and__interval_ms
The script must return an object with one or more of the following properties : data
, layout
, config
and frames
example :
let x = data.series[0].fields[0].values.buffer let y = data.series[0].fields[1].values.buffer let serie = { x : x, y : y, name : variables.project //where project is the name of a Grafana’s variable }
return { data : [serie], config : { displayModeBar: false } }
Object returned by the script and JSON provided in the Data, Layout and Config fields will be merged (deep merge).
If no script is provided, the panel will use only Data, Layout and Config fields.
Plotly panel editor :
Example of charts :
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Plotly panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Plotly panel from the commandline:
grafana-cli plugins install
