Kubernetes cluster monitoring (via Prometheus)
Monitors Kubernetes cluster using Prometheus. Shows overall cluster CPU / Memory / Filesystem usage as well as individual pod, containers, systemd services statistics. Uses cAdvisor metrics only.
Full K8 solution with dashboards, alerts and KPIs available in Grafana Cloud free tier (with 10K free Prometheus series metrics and more): https://grafana.com/signup/cloud/connect-account
Initial idea was taken from this dashboard
and improved to exclude node-exporter dependency and to give more information
about cluster state.
Requirements
You only need to have running Kubernetes cluster with deployed Prometheus. Prometheus will use metrics provided by cAdvisor via kubelet service (runs on each node of Kubernetes cluster by default) and via kube-apiserver service only.
Your Prometheus configuration has to contain following
scrape_configs:
scrape_configs:
- job_name: kubernetes-nodes-cadvisor
scrape_interval: 10s
scrape_timeout: 10s
scheme: https # remove if you want to scrape metrics on insecure port
tls_config:
ca_file: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt
bearer_token_file: /var/run/secrets/kubernetes.io/serviceaccount/token
kubernetes_sd_configs:
- role: node
relabel_configs:
- action: labelmap
regex: __meta_kubernetes_node_label_(.+)
# Only for Kubernetes ^1.7.3.
# See: https://github.com/prometheus/prometheus/issues/2916
- target_label: __address__
replacement: kubernetes.default.svc:443
- source_labels: [__meta_kubernetes_node_name]
regex: (.+)
target_label: __metrics_path__
replacement: /api/v1/nodes/${1}/proxy/metrics/cadvisor
metric_relabel_configs:
- action: replace
source_labels: [id]
regex: '^/machine\.slice/machine-rkt\\x2d([^\\]+)\\.+/([^/]+)\.service$'
target_label: rkt_container_name
replacement: '${2}-${1}'
- action: replace
source_labels: [id]
regex: '^/system\.slice/(.+)\.service$'
target_label: systemd_service_name
replacement: '${1}'
Features
- Total and used cluster resources: CPU, memory, filesystem.
And total cluster network I/O pressure.
- Kubernetes pods usage:
CPU, memory, network I/O.
- Containers usage: CPU, memory, network I/O.
Docker and rkt containers which runs on cluster nodes but outside Kubernetes are also monitored.
- systemd system services
usage: CPU, memory.
- Showing all above metrics both for all cluster and each node separately.
Troubleshooting
If filesystem usage panels display N/A, you should correct
device=~"^/dev/[vs]da9$" filter parameter in metrics query with devices your
system actually has.
Kubernetes
