Shelly Plug Power Usage
A dashboard to show power usage from a Shelly Plug
Shelly Plug Power Usage screenshot 1
This dashboard visualizes data collected from a Shelly Plug.
To collect data from a Shelly Plug I have written and documented an exporter.
The screenshot shows all collected and visualized metrics.
(Temperature is only available on the Shelly Plug S)
You can take this as a base and change what you need to use it for something else.
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
