1 Node Exporter for Prometheus Dashboard EN 20201010
【English version】Update 2020.10.10, add the overall resource overview! Support Grafana6&7,Support Node Exporter v0.16 and above.Optimize the main metrics display. Includes: CPU, memory, disk IO, network, temperature and other monitoring metrics。https://github.com/starsliao/Prometheus
The 1 Node Exporter for Prometheus Dashboard EN 20201010 dashboard uses the prometheus data source to create a Grafana dashboard with the bargauge, graph, stat and table-old panels.
RevisionDescriptionCreated
Linux Server
Linux Server
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
