Rabbit Monitor
Simple server monitor written in Rust
RabbitMonitor2
Rabbit Monitor is a simple program written in Rust that collects computer stats every 3 seconds (By default) and create /metrics API endpoint for other programs like Prometheus, Grafana... to collect data and display it.
API Endpoints:
Available options:
-a, --address <ADDRESS> Bind the server to specific address [default: 0.0.0.0]
-p, --port <PORT> Bind the server to specific port [default: 8088]
-c, --cache <CACHE> Cache time in seconds [default: 3]
-t, --token <TOKEN> Bearer token for authentication (optional)
--interfaces <INTERFACES> Comma-separated list of network interfaces to monitor (e.g., "eth0,wlan0")
--all-metrics Enable all detailed metrics
--cpu-details Enable detailed CPU metrics
--memory-details Enable detailed memory metrics
--swap-details Enable detailed swap metrics
--storage-details Enable detailed storage metrics
--network-details Enable detailed network metrics
-h, --help Print help
-V, --version Print version
Installation
# Download the binary
wget https://github.com/Rabbit-Company/RabbitMonitor2/releases/latest/download/rabbitmonitor-$(uname -m)-gnu
# Set file permissions
sudo chmod 777 rabbitmonitor-$(uname -m)-gnu
# Place the binary to `/usr/local/bin`
sudo mv rabbitmonitor-$(uname -m)-gnu /usr/local/bin/rabbitmonitor
# Start the monitor
rabbitmonitor
Daemonizing (using systemd)
Running Rabbit Monitor in the background is a simple task, just make sure that it runs without errors before doing this. Place the contents below in a file called rabbitmonitor.service in the /etc/systemd/system/ directory.
[Unit]
Description=Rabbit Monitor
After=network.target
[Service]
Type=simple
User=root
ExecStart=rabbitmonitor –interfaces eth0 –all-metrics
TimeoutStartSec=0
TimeoutStopSec=2
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
Then, run the commands below to reload systemd and start Rabbit Monitor.
systemctl enable --now rabbitmonitor
Upgrade
# Stop service
systemctl stop rabbitmonitor
Download Rabbit Monitor
Start service
systemctl start rabbitmonitor
Grafana Dashboard
Rabbit Monitor has a pre-made Grafana dashboard that looks like this:
It can be installed from official Grafana website: https://grafana.com/grafana/dashboards/18562
