Home Energy Usage v2
A dashboard that shows your home energy usage. Using Prometheus, Home Assistant and the Emporia Vue 2.
The Home Energy Usage v2 dashboard uses the prometheus data source to create a Grafana dashboard with the bargauge, graph, piechart, stat and timeseries panels.
RevisionDescriptionCreated
Home Assistant
Home Assistant
by Grafana Labs
Grafana Labs solution
Easily monitor Home Assistant, an open source software platform designed for home automation, with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
