Cosmos Monitoring System
easy to use. cosmos network monitor
The Cosmos Monitoring System dashboard uses the prometheus data source to create a Grafana dashboard with the bargauge, gauge, graph, stat, table, table-old, text and timeseries panels.
RevisionDescriptionCreated
Azure Cosmos DB
Azure Cosmos DB
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
