Docker and system monitoring (nodeexporter v1.3.1)
A simple overview of the most important Docker host and container metrics. (cAdvisor/Prometheus)
Docker and system monitoring (nodeexporter v1.3.1) screenshot 1
This is a fork of https://grafana.com/grafana/dashboards/893 with some panels updated for to account for changes in newer versions of prom/node-exporter.
Docker + System dashboard
Dashboard compatible with Grafana 4
System metric
This dashboard display Docker and system metric, the aim it's to have all the metric on one dashboard. The first lines represents the system metric with gauge and text/graph (easy to visualize and minimalist).
Time up
Memory usage/swap
Disk usage
Load
Network
CPU usage
Disk I/O
Alerts are set on disk usage, memory usage and load usage to warn when the metric are critics.
Docker metric
The second parts of the dashboard is Docker metric, more detailed using mostly graph.
CPU usage per container
Sent network per container
Received network per container
Memory usage/swap per container
Remaining memory for each container (if men_limit defined in docker-compose.yml)
Server configuration
I use the docker-compose to set my monitoring: https://github.com/vegasbrianc/prometheus. My dashboard work with this configuration. Service running:
docker
prometheus
node-exporter
alertmanager
cadvisor
grafana
Install with docker-compose.yml
docker-compose.yml
prometheus:
    image: prom/prometheus:latest
    container_name: monitoring_prometheus
    restart: unless-stopped
    volumes:
      - ./data/prometheus/config:/etc/prometheus/
      - ./data/prometheus/data:/prometheus
    command:
      - '-config.file=/etc/prometheus/prometheus.yml'
      - '-storage.local.path=/prometheus'
      - '-alertmanager.url=http://alertmanager:9093'
    expose:
      - 9090
    ports:
      - 9090:9090
    links:
      - cadvisor:cadvisor
      - node-exporter:node-exporter
node-exporter: image: prom/node-exporter:latest container_name: monitoring_node_exporter restart: unless-stopped expose: - 9100
cadvisor: image: google/cadvisor:latest container_name: monitoring_cadvisor restart: unless-stopped volumes: - /:/rootfs:ro - /var/run:/var/run:rw - /sys:/sys:ro - /var/lib/docker/:/var/lib/docker:ro expose: - 8080
grafana: image: grafana/grafana:latest container_name: monitoring_grafana restart: unless-stopped links: - prometheus:prometheus volumes: - ./data/grafana:/var/lib/grafana environment: - GF_SECURITY_ADMIN_PASSWORD=MYPASSWORT - GF_USERS_ALLOW_SIGN_UP=false - GF_SERVER_DOMAIN=myrul.com - GF_SMTP_ENABLED=true - GF_SMTP_HOST=smtp.gmail.com:587 - GF_SMTP_USER=myadrress@gmail.com - GF_SMTP_PASSWORD=mypassword - GF_SMTP_FROM_ADDRESS=myaddress@gmail.com
prometheus.yml
# my global config
global:
  scrape_interval:     120s # By default, scrape targets every 15 seconds.
  evaluation_interval: 120s # By default, scrape targets every 15 seconds.
  # scrape_timeout is set to the global default (10s).
Attach these labels to any time series or alerts when communicating with
external systems (federation, remote storage, Alertmanager).
external_labels: monitor: 'my-project'
Load and evaluate rules in this file every 'evaluation_interval' seconds.
rule_files:
- "alert.rules"
- "first.rules"
- "second.rules"
A scrape configuration containing exactly one endpoint to scrape:
Here it's Prometheus itself.
scrape_configs:
The job name is added as a label job=<job_name> to any timeseries scraped from this config.
  • job_name: 'prometheus'
    Override the global default and scrape targets from this job every 5 seconds.
    metrics_path defaults to '/metrics'
    scheme defaults to 'http'.
    static_configs: - targets: ['localhost:9090','cadvisor:8080','node-exporter:9100', 'nginx-exporter:9113']
Start your docker
Run docker-compose up -d
RevisionDescriptionCreated
Docker
Docker
by Grafana Labs
Grafana Labs solution
Easily monitor Docker with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
