Purple Air PAII Air Quality
Grafana Dashboard for use with the purple_exporter Prometheus exporter.
Purple Air PAII Air Quality screenshot 1
purple_exporter Dashboard
This Dashboard is an example for use alongside purple_exporter. Instructions for setting up the associated Prometheus exporter can be found with the purple_exporter Github repo.
This dashboard displays the following information, as collected from a PAII Purple Air Sensor connected to an instance of purple_exporter.
  • Air Temperature
  • Air Pressure
  • Ambient Humidity
  • Particle Estimated Mass Concentration for Sensors A and B of particles less than:
    • 1.0 uM in diameter
    • 2.0 uM in diameter
    • 10.0 uM in diameter
  • Particle Counts for Sensors A and B of particles greater than:
    • 0.3 uM in diameter
    • 0.5 uM in diameter
    • 2.5 uM in diameter
    • 5.0 uM in diameter
As Purple Air asks that API requests be limited to once every 5 minutes, the default, and fastest refresh rate for this dashboard is 5 minutes.
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
