NGINX Landscape
NGINX Instance Manager landscape
Predefined dashboard to observe NGINX metrics on Open Source and Plus instances using NGINX Instance Manager.
Requirements
NGINX Instance Manager deployed with NGINX Agent on OSS and Plus instances.
NGINX Instance Manager Documentation can be used to install. To configure the dashboard, you can follow these instructions.
NGINX
Easily monitor NGINX, an open source software for web serving, reverse proxying, caching, load balancing, media streaming, and more, with Grafana Cloud's out-of-the-box monitoring solution.
