Solidfire Volume Detail
Solidfire Volume Detail powered by https://github.com/mjavier2k/solidfire-exporter
Solidfire Volume Detail screenshot 1
NetApp SolidFire Volume Detail
Since revision 2, this dashboard requires version v0.6.0 or higher of solidfire-exporter
The volume details dashboard contains information about:
  • Volume size
  • iSCSI Sessions
  • Read/Write latency
  • Read/Write Bytes
  • Burst Credit
  • Average IOP size
  • Unaligned read/write bytes
  • Throttling
  • QoS
See also:
The sfcluster label is required for the dashboard to work properly - be sure to add it in your Prometheus scrape config:
yaml
- job_name: solidfire_exporter
  honor_timestamps: true
  scrape_interval: 30s
  scrape_timeout: 20s
  metrics_path: /metrics
  scheme: http
  static_configs:
  - targets:
    - localhost:9987
    labels:
      sfcluster: sfcluster01
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
