RARE/freeRouter - Distance Vector IGP interface
Display distance vector IGP interface metrics
RARE/freeRouter - Distance Vector IGP interface screenshot 1
scope:local to freeRouter node
freeRouter Prometheus configuration: (copy & paste in freeRouter CLI)
  • Create hardware and software sensor
sensor dvigp4int
path dvigp4int/peer/peer
prefix freertr-dvigp4int
key name dvigp4int/peer
command sho ipv4 pvrp 1 interface
prepend dvigp4_iface_
name 0 proto="pvrp1",ifc=
replace \. _
column 1 name neighbors
exit
sensor dvigp4peer path dvigp4peer/peer/peer prefix freertr-dvigp4peer key name dvigp4peer/peer command sho ipv4 pvrp 1 summary prepend dvigp4_peers_ name 4 proto="pvrp1",ip= replace . _ column 5 name learn column 6 name advert . exit
sensor dvigp6int path dvigp6int/peer/peer prefix freertr-dvigp6int key name dvigp6int/peer command sho ipv6 pvrp 1 interface prepend dvigp6_iface_ name 0 proto="pvrp1",ifc= replace . _ column 1 name neighbors . exit
sensor dvigp6peer path dvigp6peer/peer/peer prefix freertr-dvigp6peer key name dvigp6peer/peer command sho ipv6 pvrp 1 summary prepend dvigp6_peers_ name 4 proto="pvrp1",ip= replace : _ column 5 name learn column 6 name advert . exit
  • freeRtr server Prometheus agent configuration
server prometheus pr
 sensor dvigp4int
 sensor dvigp4peer
 sensor dvigp6peer
 vrf <PROMETHEUS_VRF>
 exit
  • Prometheus server configuration (sample config with 2 nodes)
global:
  scrape_interval: 15s
  scrape_timeout: 10s
  evaluation_interval: 30s
alerting:
  alertmanagers:
  - static_configs:
    - targets: []
    scheme: http
    timeout: 10s
scrape_configs:
- job_name: router
  scrape_timeout: 10s
  metrics_path: /metrics
  scheme: http
  static_configs:
  - targets:
    - <prometheus_agent_ip_1>:9001
    labels:
      node_name: <prometheus_agent_1_node_name>
  - targets:
    - <prometheus_agent_ip_2>:9001
    labels:
      node_name: <prometheus_agent_2_node_name>
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
