RARE/freeRouter - Link state IGP interface
Display IGP link state interface metrics
RARE/freeRouter - Link state IGP interface screenshot 1
scope:local to freeRouter node
freeRouter Prometheus configuration: (copy & paste in freeRouter CLI)
  • Create hardware and software sensor
sensor lsigp4int
path lsigp4int/peer/peer
prefix freertr-lsigp4int
key name lsigp4int/peer
command sho ipv4 ospf 1 interface
prepend lsigp4_iface_
name 0 proto="ospf1",ifc=
replace \. _
column 1 name neighbors
exit
sensor lsigp4peer path lsigp4peer/peer/peer prefix freertr-lsigp4peer key name lsigp4peer/peer command sho ipv4 ospf 1 topology 0 | inc reach prepend lsigp4_peers_ name 0 proto="ospf1",node= replace . _ column 2 name reachable column 2 replace false 0 column 2 replace true 1 column 3 name neighbors . exit
sensor lsigp4perf path lsigp4perf/peer/peer prefix freertr-lsigp4perf key name lsigp4perf/peer command sho ipv4 ospf 1 spf 0 | inc reachable|fill|calc|run prepend lsigp4_perf_ labels proto="ospf1" skip 0 column 1 name val . exit
sensor lsigp6int path lsigp6int/peer/peer prefix freertr-lsigp6int key name lsigp6int/peer command sho ipv6 ospf 1 interface prepend lsigp6_iface_ name 0 proto="ospf1",ifc= replace . _ column 1 name neighbors . exit
sensor lsigp6peer path lsigp6peer/peer/peer prefix freertr-lsigp6peer key name lsigp6peer/peer command sho ipv6 ospf 1 topology 0 | inc reach prepend lsigp6_peers_ name 0 proto="ospf1",node= replace . _ replace / _ column 2 name reachable column 2 replace false 0 column 2 replace true 1 column 3 name neighbors . exit
sensor lsigp6perf path lsigp6perf/peer/peer prefix freertr-lsigp6perf key name lsigp6perf/peer command sho ipv6 ospf 1 spf 0 | inc reachable|fill|calc|run prepend lsigp6_perf_ labels proto="ospf1" skip 0 column 1 name val . exit
  • freeRtr server Prometheus agent configuration
server prometheus pr
 sensor lsigp4int
 sensor lsigp4peer
 sensor lsigp4perf
 sensor lsigp6int
 sensor lsigp6peer
 sensor lsigp6perf
 vrf <PROMETHEUS_VRF>
 exit
  • Prometheus server configuration (sample config with 2 nodes)
global:
  scrape_interval: 15s
  scrape_timeout: 10s
  evaluation_interval: 30s
alerting:
  alertmanagers:
  - static_configs:
    - targets: []
    scheme: http
    timeout: 10s
scrape_configs:
- job_name: router
  scrape_timeout: 10s
  metrics_path: /metrics
  scheme: http
  static_configs:
  - targets:
    - <prometheus_agent_ip_1>:9001
    labels:
      node_name: <prometheus_agent_1_node_name>
  - targets:
    - <prometheus_agent_ip_2>:9001
    labels:
      node_name: <prometheus_agent_2_node_name>
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
