This is documentation for the next version of Grafana Pyroscope documentation. For the latest stable release, go to the latest version.
Migrate from v1 to v2 storage using Helm
This guide walks you through migrating a Pyroscope installation from v1 to v2 storage architecture using the Helm chart. The migration uses a phased approach that lets you run both storage backends simultaneously before fully cutting over to v2.
For an overview of what changed in v2 and why, refer to About the v2 architecture and Design motivation.
Prerequisites
Before starting the migration, make sure you have:
Helm chart version 1.19.2 or later. Verify with:
helm list -n pyroscope -f pyroscopeCheck that the
CHARTcolumn showspyroscope-1.19.2or higher. If your chart is older, upgrade it first.Pyroscope running on v1 storage via Helm. Verify with:
helm get values -n pyroscope pyroscope -o yaml | grep -A2 'storage:'You should see
v1: trueandv2: false(orv2absent, since v1 is the default). If you seev2: true, your installation is already using v2 or is mid-migration.Persistence enabled (
pyroscope.persistence.enabled=true).Object storage configured. v2 writes directly to object storage — it doesn’t use local disk for block storage. If you haven’t configured object storage yet, add it to your Helm values. For example, for S3:
pyroscope: structuredConfig: storage: backend: s3 s3: endpoint: s3.us-east-1.amazonaws.com bucket_name: pyroscope-data access_key_id: "${AWS_ACCESS_KEY_ID}" secret_access_key: "${AWS_SECRET_ACCESS_KEY}"For other backends (GCS, Azure, Swift), refer to Configure object storage backend. You can also use the
filesystembackend, but in Kubernetes, this requires aReadWriteManyvolume that is shared across all pods.kubectlandhelmCLI access to your cluster.
Note
The examples in this guide assume Pyroscope is installed in the
pyroscopenamespace with the release namepyroscope. Adjust the-nnamespace flag and release name inhelmandkubectlcommands if your installation differs.
Migration overview
The migration has three phases:
The steps below are specific to your deployment mode. Follow the section that matches your installation.
Single-binary mode
Phase 1: Enable dual ingest
In this phase, the single-binary process enables the v2 storage modules alongside v1. Writes go to both storage backends simultaneously, and the read path serves data from both v1 and v2.
helm upgrade -n pyroscope pyroscope grafana/pyroscope \
--reuse-values \
--set architecture.storage.v1=true \
--set architecture.storage.v2=trueThe --reuse-values flag preserves your existing configuration. Alternatively, you can pass your values file with -f values.yaml.
Verify Phase 1
After the upgrade completes, check that the pod has restarted and is running:
kubectl get pods -n pyroscope -l app.kubernetes.io/instance=pyroscopeCheck the Helm release notes for migration status:
helm get notes -n pyroscope pyroscopeYou should see output similar to:
# Pyroscope v2 Migration is active
Write traffic will be written to:
- 100% v1: ingester
- 100% v2: segment-writer
Read traffic is served from v2 read path from as soon as data was first ingested to v2.Also verify:
The metastore raft has initialized. Check the pod logs for a message like
entering leader state:kubectl logs -n pyroscope -l app.kubernetes.io/instance=pyroscope --tail=500 | grep -i "entering leader state"The segment-writer ring is healthy:
kubectl port-forward -n pyroscope svc/pyroscope 4040:4040 & PF_PID=$! curl -s http://localhost:4040/ring-segment-writer | grep -o 'ACTIVE' | wc -l kill $PF_PIDIn single-binary mode, the count should be 1.
Phase 2: Validate v2 is working
Run both storage backends simultaneously for at least 24 hours before proceeding. During this time, you should be able to query data ingested to v2.
Verify data is being written to v2
Query recent profiling data. The v2 read path should serve data ingested after Phase 1. You can use profilecli, the Pyroscope UI, or the API to query profiles from the last hour and confirm results are returned:
PF_PID=$!
profilecli query series --url http://localhost:4040 --from "now-1h" --to "now"
kill $PF_PIDYou should see series labels for the profiling data being ingested. If no results are returned, check the distributor and segment-writer logs for errors.
Verify v2 compaction is running
The compaction-worker compacts segments through the L0 → L1 → L2 levels. Verify that compaction jobs are completing:
kubectl logs -n pyroscope -l app.kubernetes.io/instance=pyroscope --tail=500 | grep "compaction finished successfully"You should see log lines like:
msg="compaction finished successfully" input_blocks=20 output_blocks=1Compaction typically starts within minutes of ingestion, the first block is created once enough segments accumulate for a shard.
Verify error rates are stable
Check that write and read error rates haven’t increased since enabling v2. If you have Prometheus metrics configured:
sum(rate(pyroscope_request_duration_seconds_count{status_code=~"5.."}[5m]))Error rates should be zero or negligible. Compare against pre-migration baselines to confirm no regression.
Phase 3: Switch to v2 storage
Once you’re confident that v2 is working correctly and you no longer need to query data ingested before Phase 1, you can disable the v1 storage.
Warning
After this step, data ingested before Phase 1 is no longer queryable through Pyroscope. The data still exists in object storage, but the v1 storage modules that serve it will be disabled. Make sure you don’t need to query historical data from before the migration started.
--reuse-values \
--set architecture.storage.v1=false \
--set architecture.storage.v2=trueVerify Phase 3
Verify that the Pyroscope pod has restarted:
kubectl get pods -n pyroscope -l app.kubernetes.io/instance=pyroscopeVerify that queries still return data:
PF_PID=$!
kill $PF_PIDYou should see series labels for recent profiling data. You can also open the Pyroscope UI at http://localhost:4040 and verify that you can query recent profiles. An empty or errored UI indicates a problem — see Rollback.
Microservices mode
If you deployed Pyroscope using the values-micro-services.yaml file as described in
Deploy on Kubernetes, follow the steps below.
Phase 1: Deploy v2 components alongside v1
In this phase, you deploy the v2 components (segment-writer, metastore, compaction-worker, query-backend) alongside your existing v1 installation. The distributor starts writing to both storage backends simultaneously. The read path serves data from both v1 and v2.
--reuse-values \
--set architecture.microservices.enabled=true \
Verify Phase 1
After the upgrade completes, check that the new components are running:
- 100% v1: ingester
The metastore raft cluster has elected a leader:
kubectl logs -n pyroscope -l app.kubernetes.io/component=metastore --tail=500 | grep -i "entering leader state"The segment-writer ring is healthy. All instances should show as
ACTIVE:kubectl port-forward -n pyroscope svc/pyroscope-distributor 4040:4040 & PF_PID=$! curl -s http://localhost:4040/ring-segment-writer | grep -o 'ACTIVE' | wc -l kill $PF_PIDThe count should match the number of segment-writer instances.
kubectl port-forward -n pyroscope svc/pyroscope-query-frontend 4040:4040 &
PF_PID=$!
kubectl logs -n pyroscope -l app.kubernetes.io/component=compaction-worker --tail=500 | grep "compaction finished successfully"You should see log lines like:
Check that write and read error rates haven’t increased since enabling v2. If you have Prometheus metrics configured, query error rates per component:
# Server-side errors by component (distributor, segment-writer, query-frontend, query-backend, etc.)
sum by (component) (rate(pyroscope_request_duration_seconds_count{status_code=~"5.."}[5m]))All components should show zero or negligible error rates. Compare against pre-migration baselines to confirm no regression.
Phase 3: Remove v1 components
Once you’re confident that v2 is working correctly and you no longer need to query data ingested before Phase 1, you can remove the v1 components.
Warning
After this step, data ingested before Phase 1 is no longer queryable through Pyroscope. The data still exists in object storage, but the v1 read path components (ingester, store-gateway, querier) that serve it will be removed. Make sure you don’t need to query historical data from before the migration started.
--reuse-values \
--set architecture.storage.v2=trueThe Helm chart automatically removes v1-only components (ingester, compactor, store-gateway, querier, query-scheduler) when architecture.storage.v1 is set to false, even if your values file or --reuse-values state still contains overrides for those components.
Verify Phase 3
Check that v1 components have been removed and v2 is serving all traffic:
# v1 components (ingester, store-gateway, querier, compactor, query-scheduler) should be gone
PF_PID=$!
Rollback
During Phase 1 or Phase 2
Rolling back is straightforward — set architecture.storage.v2=false to remove the v2 components and return to v1-only:
--reuse-values \
--set architecture.storage.v2=falseData written to v2 during the dual-ingest period is orphaned but doesn’t affect v1 operation.
During or after Phase 3
If you removed v1 components (Phase 3), rolling back requires redeploying them:
--reuse-values \
--set architecture.storage.v2=trueThis returns you to dual-ingest mode (Phase 1). Note that any data ingested between Phase 3 and the rollback was only written to v2 and won’t be visible through the v1 read path.
Helm values reference
The following Helm values control the v1/v2 storage configuration and migration behavior.
Storage layer toggles
Migration tuning
These values only apply when both v1 and v2 are enabled (dual-ingest mode). All values are under architecture.storage.migration.
