This is documentation for the next version of Grafana Pyroscope documentation. For the latest stable release, go to the latest version.
Pyroscope deployment modes
You can deploy Pyroscope in one of two modes:
  • Monolithic mode: In this mode all components run in a single process and is meant to be used when you only need one pyroscope instance as multiple instances will not share information with each other
  • Microservices mode: In this mode in this mode as you scale out the number of instances, they will share a singular backend for storage and querying
The deployment mode is determined by the -target parameter, which you can set via CLI flag or YAML configuration.
Monolithic mode
The monolithic mode runs all required components in a single process and is the default mode of operation, which you can set by specifying -target=all. Monolithic mode is the simplest way to deploy Pyroscope and is useful if you want to get started quickly or want to work with Pyroscope in a development environment. To see the list of components that run when -target is set to all, run Pyroscope with the -modules flag:
Bash
./pyroscope -modules
Pyroscope’s monolithic mode
Microservices mode
In microservices mode, components are deployed in distinct processes. Scaling is per component, which allows for greater flexibility in scaling and more granular failure domains. Microservices mode is the preferred method for a production deployment, but it is also the most complex.
In microservices mode, each Pyroscope process is invoked with its -target parameter set to a specific Pyroscope component (for example, -target=ingester or -target=distributor). To get a working Pyroscope instance, you must deploy every required component. For more information about each of the Pyroscope components, refer to Architecture.
If you are interested in deploying Pyroscope in microservices mode, we recommend that you use Kubernetes.
Pyroscope’s microservices mode
