Pyroscope Block format
This document describes how Pyroscope stores the data in its blocks. Each block belongs to a single tenant and is identified by a unique ULID. Within the block there are multiple files:
A metadata file
meta.json
, which contains information about what the block contains, like the time range of the profiling data.A TSDB index
index.tsdb
mapping the external labels to the profiles stored in the profiles table.profiles.parquet
parquet table that contains profiles.symbols.symdb
that contains symbolic information for the profiles stored in the block.
Data model
The Jira Enterprise plugin is now available for users with a Grafana Cloud account or with a Grafana Enterprise license. For more information and to get started, create a free account or contact our team.
The data model within the block is fairly aligned to Google’s proto definition for the pprof wire format.
Profile series labels contain additional information gathered at ingestion time and can
be used to select certain profiles. They are comparable to Prometheus/Loki labels
and typical label names are namespace
and pod
to describe which workload the profiles
are coming from.
Each profile ingested will be added into a new row in the profile table. If there are entries missing in the tables for the different models they are also inserted.
