Documentationbreadcrumb arrow Pluginsbreadcrumb arrow Business Formsbreadcrumb arrow Form elementsbreadcrumb arrow Radio group with custom options
Enterprise Open source Grafana Cloud
The Radio Group with custom options provides users with a choice between two or more options.
This element has the following specific option:
  • User options
To add an option, click Add option, and then specify an option type (number or string), value, label, and select an icon from the list.
Add custom options for the radio custom type.
Change elements model
Note
Use this model to set elements if you use the context.panel.onChangeElements([]) method.
Dynamic element creation and manipulation through the panel fetches the complete element model and sets it through a method. The elements aren’t saved in the panel options.
js
  uid:'',
  title: '',
  type: 'radio',
  optionsSource:'',
  labelWidth: 10,
  width: 30,
  tooltip: '',
  section: '',
  unit: '',
  value: '',
  disabled: false,
  background: '',
  labelBackground:'',
  labelColor: '',
  helpers: {
    showIf: () => true,
    disableIf: () => false,
    getOptions: () => [],
Code example
JavaScript
 * Hardcoded element
const element = {
  uid: "uid-123",
  title: "Element",
  type: "radio",
  optionsSource: "Custom",
  labelWidth: 15,
  width: 150,
  tooltip: "",
  section: "",
  unit: "",
  value: "",
  background: "",
  labelBackground: "",
  labelColor: "",
  helpers: {
    showIf: () => true,
    getOptions: () => [{ value: 11, label: "11" }],
const elementsForUI = [];
elementsForUI.push(element);
context.panel.onChangeElements(elementsForUI);
Code example with query action for initial request
Initial Request
js
 * Convert JSON to form elements array
const formElements = JSON.parse(
  context.panel.data.series[0].fields[0].values[0]
 * Set elements with helpers
  formElements.map((element) => {
    const elementInForm = context.panel.elements.find(
      (item) => item.uid === element.uid
    let value = element.value;
    if (element.uid === "comment" && elementInForm) {
      value = elementInForm.value;
    return {
      ...element,
      value,
      helpers: {
        showIf: () => true,
        getOptions: () => element.options,
Element parameters
  • value
    string. Optional.
    Current element value.
  • type
    string. Required.
    Element type: ‘radio’.
  • optionsSource
    string. Required.
    Element options source: ‘Query’ | ‘Custom’ | ‘Code’.
  • uid
    string. Required.
    A unique identifier used for correct mapping on the UI.
  • id
    string. Required.
    The unique identifier of the element.
  • title
    string. Required.
    The title or label of the element. Equivalent to the ‘Label’ in the UI editor.
Label field
  • labelWidth
    Number | null . Required.
    The element label width.
  • width
    Number | null. Required.
    The element width.
  • tooltip
    string. Required.
    The element tooltip. Leave as an empty string (’’) if not displayed.
  • section
    string. Required.
    The unique section identifier (section ID). Specify this if the element is in a section. Leave as an empty string (’’) if the element has no section.
  • unit
    string. Required.
    The units of measurement. Located to the right of the element. Leave as an empty string (’’) if the element has no unit.
Unit of measurement
  • background
    string. Optional.
    The background color as a hex color code.
  • labelBackground
    string. Optional. The label background color as a hex color code.
  • labelColor
    string. Optional.
    The label color as a hex color code.
  • helpers
    Helpers provide information about the item display or its disabled state and return options.
js
  showIf: () => true,
  getOptions: () => options || [],
  • helpers.showIf
    Function. Required. Returns true or false. Controls whether the element displays on the UI.
  • helpers.disableIf
    Function. Required. Returns true or false. Controls whether the element is disabled on the UI.
  • helpers.getOptions
    Function. Required. Returns an array of options.
    Each option contains the following properties:
    • value.
      string. Required. The option value.
    • label.
      string. Required. The option label.
Change options model
Note
Use this model to set elements if you use the context.panel.onOptionsChange({}) method.
Elements added through this method are added to the panel options. The element’s operation might not match the expected behavior.
If you use this method in the initial request, disable the Synchronize option. Enabling the Synchronize option with context.panel.onOptionsChange() in the Initial Request causes the panel to reload constantly.
Disable Synchronize with data to avoid endless reloading of the panel if onOptionsChange() is used in the initial request.
js
  uid:'',
  title: '',
  type: "radio",
  queryOptions: {},
  options: [],
  getOptions: '',
  labelWidth: 10,
  width: 35,
  tooltip: '',
  section: '',
  unit: '',
  value: '',
  showIf: '',
  disableIf: '',
  fieldName: '',
  queryField: {},
  background: '',
  labelBackground:'',
  labelColor: '',
Code example
JavaScript
  ...context.panel.options,
  elements: context.panel.options.elements.map((element) => {
    return element.id === "name" ? { ...element, value: "test" } : element;
JavaScript
  elements: formElements,
  • value
    string. Optional.
  • type
    string. Required.
  • optionsSource
    string. Required.
  • getOptions
    string. Optional.
    “getOptions” function of the element returns options for list. Use for optionsSource: 'Code'.
    js
      getOptions: "return [{value:1,label:'1'}]";
  • queryOptions
    object. Optional.
    Return options from query. Use for optionsSource: 'Query'.
    Parameters:
    • source
      string. Frame refId
    • value
      string. Field name
    • label
      string. Field name
  • options
    array. Optional.
    Return options for checkbox list.
    Each option contain following property
    • value.
      string. Required. Option value
    • label.
      string. Required. Option label
  • uid
    string. Required.
  • id
    string. Required.
  • title
    string. Required.
    Label field
  • labelWidth
  • width
    The element width.
  • tooltip
    string. Required.
  • section
    string. Required.
  • unit
    string. Required.
    Unit of measurement
  • background
    string. Optional.
  • labelBackground
    string. Optional.
  • labelColor
    string. Optional.
  • showIf
    string. Optional.
    The “Show if” function of the element returns true or false. Controls whether the element displays on the UI.
    js
      showIf: "if (condition) {\n  return true\n}\n return false";
  • disableIf
    string. Optional.
    The “Disable if” function of the element returns true or false. Controls whether the element is disabled on the UI.
    js
      disableIf: "if (condition) {\n  return true\n}\n return false";
  • fieldName
    string. Optional.
    The name field from the DataSource initial request. Use for the initial value. We recommend using value instead.
  • queryField
    object. Optional.
    The name query from the Query initial request. Use for the initial value. We recommend using value instead.
    Parameters:
    • refId
      string. The frame refId.
    • value
      string. The field name.
    • label
      string. The format: refId:value (for example, A:time).
