Radio group with boolean options
The Radio Group with boolean options provides users with a choice between True and False.
This type doesn’t have any specific options.
Change elements model
Note
Use this model to set elements if you use the
context.panel.onChangeElements([])method.Dynamic element creation and manipulation through the panel fetches the complete element model and sets it through a method. The elements aren’t saved in the panel options.
uid:'',
title: '',
type: 'boolean',
labelWidth: 10,
width: 30,
tooltip: '',
section: '',
unit: '',
value: true,
disabled: false,
background: '',
labelBackground:'',
labelColor: '',
helpers: {
showIf: () => true,
disableIf: () => false,
getOptions: () => [],
}Code example
* Hardcoded element
const element = {
uid: "uid-123",
title: "Element",
type: "boolean",
labelWidth: 15,
width: 150,
tooltip: "",
section: "",
unit: "",
value: true,
background: "",
labelBackground: "",
labelColor: "",
helpers: {
showIf: () => true,
const elementsForUI = [];
elementsForUI.push(element);
context.panel.onChangeElements(elementsForUI);Code example with query action for initial request
* Convert JSON to form elements array
const formElements = JSON.parse(
context.panel.data.series[0].fields[0].values[0]
* Set elements with helpers
formElements.map((element) => {
const elementInForm = context.panel.elements.find(
(item) => item.uid === element.uid
let value = element.value;
if (element.uid === "comment" && elementInForm) {
value = elementInForm.value;
return {
...element,
value,
helpers: {
showIf: () => true,
getOptions: () => element.options,
);Element parameters
valueboolean. Required.
Current element value.typestring. Required.
Element type: ‘boolean’.
uidstring. Required.
A unique identifier used for correct mapping on the UI.idstring. Required.
The unique identifier of the element.titlestring. Required.
The title or label of the element. Equivalent to the ‘Label’ in the UI editor.
labelWidthNumber | null . Required.
The element label width.widthNumber | null. Required.
The element width.tooltipstring. Required.
The element tooltip. Leave as an empty string (’’) if not displayed.sectionstring. Required.
The unique section identifier (section ID). Specify this if the element is in a section. Leave as an empty string (’’) if the element has no section.unitstring. Required.
The units of measurement. Located to the right of the element. Leave as an empty string (’’) if the element has no unit.
backgroundstring. Optional.
The background color as a hex color code.labelBackgroundstring. Optional. The label background color as a hex color code.
labelColorstring. Optional.
The label color as a hex color code.helpersHelpers provide information about the item display or its disabled state and return options.
showIf: () => true,
getOptions: () => options || [],
}helpers.showIfFunction. Required. Returns true or false. Controls whether the element displays on the UI.
helpers.disableIfFunction. Required. Returns true or false. Controls whether the element is disabled on the UI.
helpers.getOptionsFunction. Required. Returns an array of options.
Each option contains the following properties:
value.
string. Required. The option value.label.
string. Required. The option label.
The Radio Group with boolean options element does not support options for selection. However, they must be specified in the element object
Change options model
Note
context.panel.onOptionsChange({})method.Elements added through this method are added to the panel options. The element’s operation might not match the expected behavior.
If you use this method in the initial request, disable the Synchronize option. Enabling the Synchronize option with
context.panel.onOptionsChange()in the Initial Request causes the panel to reload constantly.
uid:'',
title: '',
type: "boolean",
labelWidth: 10,
width: 35,
tooltip: '',
section: '',
unit: '',
value: true,
showIf: '',
disableIf: '',
fieldName: '',
queryField: {},
background: '',
labelBackground:'',
labelColor: '',
}Code example
...context.panel.options,
elements: context.panel.options.elements.map((element) => {
return element.id === "name" ? { ...element, value: "test" } : element;
});const formElements = JSON.parse(
elements: formElements,
});valueboolean. Required.
The title or label of the element. Equivalent to the ‘Label’ in the UI editor.![Label field]()
The units of measurement. Located to the right of the element. Leave as an empty string (’’) if the element has no unit.![Unit of measurement]()
The label background color as a hex color code.labelColorstring. Optional.
The label color as a hex color code.showIfstring. Optional.
The “Show if” function of the element returns true or false. Controls whether the element displays on the UI.{ showIf: "if (condition) {\n return true\n}\n return false"; }disableIfstring. Optional.
The “Disable if” function of the element returns true or false. Controls whether the element is disabled on the UI.{ disableIf: "if (condition) {\n return true\n}\n return false"; }fieldNamestring. Optional.
The name field from the DataSource initial request. Use for the initial value. We recommend usingvalueinstead.queryFieldobject. Optional.
The name query from the Query initial request. Use for the initial value. We recommend usingvalueinstead.Parameters:
refId
string. The frame refId.value
string. The field name.label
string. The format:refId:value(for example,A:time).
