Enterprise Open source Grafana Cloud
Context parameters
context.element
Returns the current element.
Usage
JavaScript
context.element;
Example
JavaScript
const currentElement = context.element;
Panel
panel.data
Returns the result set of panel queries.
Usage
JavaScript
context.panel.data;
Example
JavaScript
const data = context.panel.data;
panel.elements
Returns all form elements.
Usage
JavaScript
context.panel.elements;
Example
JavaScript
const currentElements = context.panel.elements;
panel.initial
Returns the parsed values from the initial request.
Usage
JavaScript
context.panel.initial;
Example
JavaScript
const initialValues = context.panel.initial;
panel.initialRequest()
Performs an initial request to reload the panel.
Usage
JavaScript
context.panel.initialRequest();
Example
JavaScript
if (context.panel.response && context.panel.response.ok) {
  context.grafana.notifySuccess(["Update", "Values updated successfully."]);
} else {
  context.grafana.notifyError([
    "Error",
    `An error occurred updating values: ${context.panel.response.status}`,
panel.options
Returns the panel’s options.
Usage
JavaScript
context.panel.options;
Example
JavaScript
const options = context.panel.options;
panel.onOptionsChange(options)
Modifies the panel options and triggers a refresh. The context.panel.onOptionsChange() handler is required to update the panel.
Note
The context.panel.onOptionsChange(options) handler calls the refresh panel.
If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with context.panel.onOptionsChange(options) in the Initial Request will cause the panel to reload constantly.
Usage
JavaScript
context.panel.onOptionsChange(options);
Example
JavaScript
context.panel.onOptionsChange({
  ...context.panel.options,
  elements: context.panel.options.elements.map((element) => {
    return element.id === "name" ? { ...element, value: "test" } : element;
JavaScript
  ...options,
  sync: true,
Arguments
  • options Object
    Panel options. Use console.log('options:',context.panel.options) to check all fields
panel.onChangeElements(options)
Updates elements in the local state. Accepts an array of new elements.
Usage
JavaScript
context.panel.onChangeElements(elements);
Example
JavaScript
  context.panel.elements.map((element) => ({
    ...element,
    value: json[element.id],
JavaScript
Arguments
  • elements Array
    Array of elements.
panel.patchFormValue(values)
Updates the values of the specified elements. Accepts an object.
Usage
JavaScript
context.panel.patchFormValue(elements);
Example
JavaScript
// only passed elements should be updated, the rest stay the same
context.panel.patchFormValue({ name: "Alex" });
JavaScript
// name and isAdmin
context.panel.patchFormValue({ name: "Alex", isAdmin: true });
Arguments
  • values Object
    Object. Each key is the id of the element and the value of the key is the value of the element
panel.setFormValue(values)
Updates the values of elements. Accepts an object. If a value is not passed for an element, the initial value is used or the value is cleared.
Usage
JavaScript
context.panel.setFormValue(elements);
Example
JavaScript
context.panel.setFormValue({ name: "Alex", isAdmin: true });
Arguments
  • values Object
panel.formValue()
Returns the current form values as an object.
Usage
JavaScript
context.panel.formValue(elements);
Example
JavaScript
const payload = context.panel.formValue;
// return { name: 'Alex', isAdmin: true }
panel.response
Returns the current request’s response.
Usage
JavaScript
context.panel.response;
Example
JavaScript
  context.grafana.refresh();
} else {
    "Update",
panel.setInitial(values)
Specifies initial values for a custom initial request to highlight modified values and requests a user’s confirmation.
Usage
JavaScript
context.panel.setInitial(values);
Example
JavaScript
// Initial custom code example
const payload = {};
context.panel.elements.forEach((element) => {
  if (!element.value) {
    return;
  payload[element.id] = element.value;
context.panel.setInitial(payload);
return;
Arguments
  • values Object
    JavaScript
    // example
      "max": 100,
      "min": 10,
      "speed": 54,
      "option1": "option1",
      "option2": "option1",
      "code": "option1"
Errors
panel.setError(message)
Displays an error on panel.
Usage
JavaScript
context.panel.setError(message);
Example
JavaScript
context.panel.setError("Message");
Arguments
  • message String
    Error Message
Buttons
panel.enableSubmit()
Enables the Submit button.
Usage
JavaScript
context.panel.enableSubmit();
Example
JavaScript
if (condition) {
panel.disableSubmit()
Disables the Submit button.
Usage
JavaScript
context.panel.disableSubmit();
Example
JavaScript
if (condition) {
panel.enableReset()
Enables the Reset button.
Usage
JavaScript
context.panel.enableReset();
Example
JavaScript
if (condition) {
panel.disableReset()
Disables the Reset button.
Usage
JavaScript
context.panel.disableReset();
Example
JavaScript
if (condition) {
panel.enableSaveDefault()
Enables the Save Default button.
Usage
JavaScript
context.panel.enableSaveDefault();
Example
JavaScript
if (condition) {
panel.disableSaveDefault()
Disables the Save Default button.
Usage
JavaScript
context.panel.disableSaveDefault();
Example
JavaScript
if (condition) {
Sections Utils
sectionsUtils.add(section)
Adds a new section.
Added in: v4.9.0
Note
The context.panel.sectionsUtils.add(section) handler calls the refresh panel.
If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with context.panel.sectionsUtils.add(section) in the Initial Request will cause the panel to reload constantly.
Usage
JavaScript
context.panel.sectionsUtils.add(section);
Example
JavaScript
context.panel.sectionsUtils.add({
  elements: [],
const newSection = {
  elements: ["elem-1", "elem-2"],
context.panel.sectionsUtils.add(newSection);
Arguments
  • section Object
    Section. Each section include name, id, elements
Common Section properties
  • name string. Section name.
  • id string. Section Id.
  • elements Array. Elements ids assign to section. Could Be empty array.
sectionsUtils.update(sections)
Updates existing sections.
Added in: v4.9.0
Note
The context.panel.sectionsUtils.update(sections) handler calls the refresh panel.
If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with context.panel.sectionsUtils.update(sections) in the Initial Request will cause the panel to reload constantly.
Usage
JavaScript
context.panel.sectionsUtils.update(sections);
Example
JavaScript
context.panel.sectionsUtils.update([{ name: "Section 1", id: "id-s-1" }]);
Arguments
  • sections Array
    Sections. Each section include name and id
sectionsUtils.remove(id)
Removes a section.
Added in: v4.9.0
Note
The context.panel.sectionsUtils.remove(id) handler calls the refresh panel.
If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with context.panel.sectionsUtils.remove(id) in the Initial Request will cause the panel to reload constantly.
Usage
JavaScript
context.panel.removeSection(id);
Example
JavaScript
context.panel.removeSection("id-s-1");
Arguments
  • id string. Section id.
sectionsUtils.assign(id,elements)
Assigns elements to a section.
Added in: v4.9.0
Note
The context.panel.sectionsUtils.assign(id,elements) handler calls the refresh panel.
If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with context.panel.sectionsUtils.assign(id,elements) in the Initial Request will cause the panel to reload constantly.
Usage
JavaScript
context.panel.sectionsUtils.assign(id, elements);
Example
JavaScript
context.panel.sectionsUtils.assign("id-s-1", ["elem-1", "elem-2"]);
Arguments
  • elements Array. Array of elements ids
sectionsUtils.unassign(elements)
Unassigns elements from a section.
Added in: v4.9.0
Note
The context.panel.sectionsUtils.unassign(elements) handler calls the refresh panel.
If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with context.panel.sectionsUtils.unassign(elements) in the Initial Request will cause the panel to reload constantly.
Usage
JavaScript
context.panel.sectionsUtils.unassign(elements);
Example
JavaScript
context.panel.sectionsUtils.unassign(["elem-1", "elem-2"]);
Arguments
sectionsUtils.get(id)
Returns the section with the specified ID, including all elements assigned to it.
Added in: v4.9.0
Usage
JavaScript
context.panel.sectionsUtils.get(id);
Example
JavaScript
context.panel.sectionsUtils.get("section-id");
Arguments
sectionsUtils.getAll()
Returns all sections with their assigned elements.
Added in: v4.9.0
Usage
JavaScript
context.panel.sectionsUtils.getAll();
Example
JavaScript
sectionsUtils.collapse(id)
Collapses the specified section.
Updated in: v4.9.0
Usage
JavaScript
context.panel.sectionsUtils.collapse(id);
Example
JavaScript
context.panel.sectionsUtils.collapse("section-id");
Arguments
sectionsUtils.expand(id)
Expands the specified section.
Added in: v4.9.0
Usage
JavaScript
context.panel.sectionsUtils.expand(id);
Example
JavaScript
context.panel.sectionsUtils.expand("section-id");
Arguments
sectionsUtils.toggle(id)
Toggles the specified section between collapsed and expanded states.
Added in: v4.9.0
Usage
JavaScript
context.panel.sectionsUtils.toggle(id);
Example
JavaScript
context.panel.sectionsUtils.toggle("section-id");
Arguments
sectionsUtils.expandedState
Returns Expand/Collapse State for Sections.
Added in: v4.9.0
Usage
JavaScript
context.panel.sectionsUtils.expandedState;
Example
JavaScript
const sectionsExpandedState = context.panel.sectionsUtils.expandedState;
Grafana
grafana.locationService
Provides access to Grafana’s locationService for working with the browser’s location and history.
Usage
JavaScript
context.grafana.locationService;
Example
JavaScript
context.grafana.locationService.reload();
const history = context.grafana.locationService.history;
grafana.backendService
Provides access to Grafana’s backendService for communicating with remote backends such as the Grafana backend or a data source.
Usage
JavaScript
context.grafana.backendService;
Example
JavaScript
const deviceID = context.grafana.backendService.deviceID;
grafana.notifyError([header, message])
Displays an error.
Usage
JavaScript
context.grafana.notifyError([header, message]);
Example
JavaScript
  "Error",
context.grafana.notifyError(["Error Title", `Show error message`]);
Displays an error.
Arguments
  • header string. Error title
  • message string. Error message
grafana.notifySuccess([header, message])
Displays a success notification.
Usage
JavaScript
context.grafana.notifySuccess([header, message]);
Example
JavaScript
context.grafana.notifySuccess(["Success Title", `Success message`]);
Arguments
  • header string. Success title
  • message string. Success message
grafana.notifyWarning([header, message])
Displays a warning.
Usage
JavaScript
context.grafana.notifyWarning([header, message]);
Example
JavaScript
context.grafana.notifyWarning(["warning Title", `warning message`]);
Arguments
  • header string. Warning title
  • message string. Warning message
grafana.eventBus
Publish and subscribe to application events.
Usage
JavaScript
context.grafana.eventBus;
Example
JavaScript
const subscriber = eventBus.getStream(RefreshEvent).subscribe(() => {
  // to do
grafana.templateService
Provides access to Grafana’s templateService for working with variables and updating the time range.
Usage
JavaScript
context.grafana.templateService;
Example
JavaScript
const regEx = context.grafana.templateService.regex;
grafana.refresh()
Refreshes dashboard panels using application events.
Usage
JavaScript
Utils
utils.fileToBase64(file)
Converts a file to base64 format.
Usage
JavaScript
context.utils.fileToBase64(file);
Example
JavaScript
const payload = {};
    return;
 * Data Source payload
const getPayload = async () => {
  const file = payload.file[0];
  const base64 = await context.utils.fileToBase64(file);
  return {
    file,
    base64,
return getPayload();
Arguments
  • file File. A File provides information about files.
utils.toDataQueryResponse(res)
Parses the results from /api/ds/query into a DataQueryResponse object.
Usage
JavaScript
context.utils.toDataQueryResponse(res);
Example
JavaScript
const dataQuery = context.utils.toDataQueryResponse(context.panel.response);
Arguments
  • res response. The HTTP response data
