Context parameters
context.echarts
Apache ECharts library.
Usage
JavaScript
context.echarts;
Example
JavaScript
const libraryECharts = context.echarts;
context.ecStat
A statistical and data mining tool for Apache ECharts.
Usage
JavaScript
context.ecStat;
Example
JavaScript
context.echarts.registerTransform(context.ecStat.transform.regression);
Visual Editor
editor.dataset
ECharts dataset in Visual mode.
Usage
JavaScript
context.editor.dataset;
Example
JavaScript
return {
  dataset: context.editor.dataset,
  series: context.editor.series,
  grid: {
    bottom: "3%",
    containLabel: true,
    left: "3%",
    right: "4%",
    top: "4%",
  toolbox: {
    left: "center",
    feature: {
      dataZoom: {
        yAxisIndex: "none",
      restore: {},
  xAxis: {
    type: "category",
  yAxis: {
    type: "value",
editor.series
ECharts series in Visual mode.
Usage
JavaScript
context.editor.series;
Example
JavaScript
return {
  grid: {
    bottom: "3%",
    containLabel: true,
    left: "3%",
    right: "4%",
    top: "4%",
  toolbox: {
    left: "center",
    feature: {
      dataZoom: {
        yAxisIndex: "none",
      restore: {},
  xAxis: {
    type: "category",
  yAxis: {
    type: "value",
Grafana
grafana.eventBus
Publish and subscribe to application events.
Usage
JavaScript
context.grafana.eventBus;
Example
JavaScript
const subscriber = eventBus.getStream(RefreshEvent).subscribe(() => {
  // to do
grafana.locationService
The locationService works with the browser location and history.
Usage
JavaScript
context.grafana.locationService;
Example
JavaScript
context.grafana.locationService.reload();
const history = context.grafana.locationService.history;
grafana.notifyError([header, message])
Displays an error notification.
Usage
JavaScript
context.grafana.notifyError([header, message]);
Example
JavaScript
context.grafana.notifyError(["Error Title", `Show error message`]);
Arguments
  • header string. Error title
  • message string. Error message
grafana.notifySuccess([header, message])
Displays a success notification.
Usage
JavaScript
context.grafana.notifySuccess([header, message]);
Example
JavaScript
context.grafana.notifySuccess(["Success Title", `Success message`]);
Arguments
  • header string. Success title
  • message string. Success message
grafana.refresh()
Function to refresh dashboard panels using application events.
Usage
JavaScript
context.grafana.refresh();
grafana.replaceVariables()
The replaceVariables() function to interpolate variables.
Usage
JavaScript
context.grafana.replaceVariables();
Example
JavaScript
const variable = context.grafana.replaceVariables("${variable}");
console.log(variable.toUpperCase());
grafana.theme
Contains grafana Theme object.
Usage
JavaScript
context.grafana.theme;
Example
JavaScript
const theme = context.grafana.theme;
console.log(theme);
Panel
panel.chart
Instance of the Apache ECharts library.
Usage
JavaScript
context.panel.chart;
Example
JavaScript
context.panel.chart.on("brushSelected", function (params) {
  var brushed = [];
  var brushComponent = params.batch[0];
  for (var sIdx = 0; sIdx < brushComponent.selected.length; sIdx++) {
    var rawIndices = brushComponent.selected[sIdx].dataIndex;
    brushed.push("[Series " + sIdx + "] " + rawIndices.join(", "));
  context.panel.chart.setOption({
    title: {
      backgroundColor: "#333",
      text: "SELECTED DATA INDICES: \n" + brushed.join("\n"),
      bottom: 0,
      right: "10%",
      width: 100,
      textStyle: {
        fontSize: 12,
        color: "#fff",
panel.data
Object containing a time range, series, and request information.
Usage
JavaScript
context.panel.data;
Example
JavaScript
context.panel.data.series.map((s) => {
  categories = s.fields.find((f) => f.name === "Category").values;
  values = s.fields.find((f) => f.name === "Value").values;
