Documentationbreadcrumb arrow Pluginsbreadcrumb arrow Honeycomb data source for Grafana
The Honeycomb data source for Grafana allows you to query and visualize Honeycomb metrics and link to Honeycomb traces from within Grafana.
Requirements
This plugin has the following requirements:
Known limitations
  • The Honeycomb API this data source is developed against is not yet generally available. It may cause unexpected behavior in the data source.
  • This data source does not yet support or ad-hoc queries.
  • Due to API limitations, the variable editor can only return the first 1000 unique values for a selected column.
  • Due to API limitations, the data source can only query the last 7 days’ worth of data.
  • The use of __all__ as the dataset slug to list all columns is not supported for classic environments, per Honeycomb documentation.
Install the data source plugin
To install the data source, refer to Installation.
Conform to compatibility requirements
For this plugin, there are no compatibility requirements.
Verify that the plugin is installed
  1. In Grafana Enterprise from the left-hand menu, navigate to Configuration > Data sources.
  2. From the top-right corner, click the Add data source button.
  3. Search for Honeycomb in the search field, and hover over the Honeycomb search result.
  4. Click the Select button for Honeycomb.
    • If you can click the Select button, then it is installed.
    • If the button is missing or disabled, then the plugin is not installed. Check to see if your Grafana Enterprise license is valid, and reinstall the plugin. If you still need help, contact Grafana Labs.
Note: On Grafana Cloud, it can take up to 15 minutes to see the data source plugin within Grafana.
Get an API key from Honeycomb
  1. Go to https://ui.honeycomb.io/account.
  2. Set up an API key and copy your application key.
Configure the data source
To add a new Honeycomb data source, refer to Add a data source, and fill in the following fields:
Honeycomb settings
FieldDescription
NameA name for this particular Honeycomb data source.
Honeycomb API KeyAPI key from Honeycomb.
URLURL to the Honeycomb API. For example, https://api.honeycomb.io.
TeamThe Honeycomb team associated with the API key
EnvironmentHoneycomb environment name associated with the API key
Configuration
Configure the data source with provisioning
Configure the Honeycomb data source using configuration files with Grafana’s provisioning system. To know more about how the provisioning system works, including all of the data source settings, refer to Provisioning Grafana.
Here is a provisioning example for this data source:
YAML
apiVersion: 1
datasources:
  - name: Honeycomb
    type: grafana-honeycomb-datasource
    jsonData:
      hostname: https://api.honeycomb.io
      team: Team
      environment: test
    secureJsonData:
      apiKey: API Key
Query the data source
The query editor allows you to query and link to Honeycomb.
query-editor
Depending on the value selected for the Returned data dropdown Query will return either timeseries data, results (equivalent to the Overview in the Honeycomb UI below the graph) or both.
data frames
Metrics Query
Query metrics by entering values into the editor fields.
  • Select a dataset
  • The default query is a COUNT over the selected dataset.
  • To refine the query, select values for any of the remaining fields: Visualization, Where, Constriant, Group by, Order by, or Limit.
SLO Query
Honeycomb SLOs can be queried by choosing SLO as query type. There are two types of SLO queries you can perform
  1. List of SLO definitions (SLO List)
  2. Individual SLO detail (SLO detail)
    • This query require a single SLO ID.
    • To retrieve the Budget Remaining and Compliance details, Honeycomb enterprise plan is required.
To view SLO details of multiple SLO items, use multiple queries and then use merge transform to get them into single panel view.
Raw Query
The Honeycomb data source now supports raw queries through a JSON-based interface, allowing users to leverage the full power of the Honeycomb API directly within Grafana. This feature provides access to advanced querying capabilities that may not be available through the standard query builder interface.
Raw Query requires the honeycombEnableRawQuery feature flag to be enabled, If you are are Grafana Cloud customer, please contact support to request access, and let us know what you think!
To access the raw query functionality, select the “Raw Query” option from the query type dropdown in the Honeycomb query builder. This opens a JSON text area where you can input queries in the same format accepted by the Honeycomb API.
The feature supports all operations available in the Honeycomb API, including filters, columns, aggregations, transformations, breakdowns, calculations, granularity settings, ordering, and result set filtering with AND/OR logic combinations. By default, queries will use the time range specified in the Grafana panel, but you can override this by including explicit start_time and end_time parameters in your JSON query. Similarly, specifying a granularity value in the query will override Grafana’s automatic granularity calculation based on the selected time range.
Templates and variables
To add a new Honeycomb query variable, refer to Add a query variable. Use your Honeycomb data source as your data source.
Screenshot from 2021-06-17 14-41-10
You can create variables containing Datasets, Columns, or Column Values:
  • If no dataset is selected, the variable will contain datasets
  • If only a dataset is selected, the variable will contain column names
  • If both a dataset and a column are selected, the variable will contain column values.
    • Column values can be further constrained using the Where fields in the editor.
After you create a variable, you can it in your Honeycomb queries. For more information, refer to Variable syntax.
For more information about variables, refer Templates and variables.
View query in Honeycomb UI
From the Dashboard Panel
To see the query you have created in the Honeycomb UI from the dashboard panel, click on any point in the graph and click Open in Honeycomb
Screenshot from 2021-07-22 15-38-33
From the Query Editor
To see the query you have created in the Honeycomb UI, click the Open in Honeycomb button.
Screenshot from 2021-06-17 14-36-42
Import a dashboard for Honeycomb
To import a dashboard, refer to Import a dashboard.
To find your imported dashboards, go to Configuration > Data sources.
To see the available pre-made dashboards, select the Honeycomb data source, and select the Dashboards tab.
