Cloudflare data source
The Cloudflare data source allows you to query and visualize data from Cloudflare in Grafana, including DNS analytics and Cloudflare Radar data.
Note
Cloudflare data source plugin is currently in public preview. Grafana Labs offers limited support, and breaking changes might occur prior to the feature being made generally available.
Note
The Cloudflare data source is an Enterprise plugin. It’s available with Grafana Cloud (Free, Pro, and Advanced tiers) and Grafana Enterprise. For installation instructions, refer to Install Grafana Enterprise plugins.
Requirements
To use this data source, you need:
- A Cloudflare account with an API token (user tokens only; account-owned tokens aren’t supported)
- A Grafana Cloud account or an activated Grafana Enterprise license
Version compatibility
Supported features
Get started
The following documents help you set up and use the Cloudflare data source:
Additional features
After configuring the data source, you can:
- Create annotations to mark events on your graphs
- Set up alerting to get notified about Cloudflare data
- Use Explore to query data without building a dashboard
- Add Transformations to manipulate query results
Additional resources
Plugin updates
Always ensure that your plugin version is up-to-date so you have access to all current features and improvements. Navigate to Plugins and data > Plugins to check for updates. Grafana recommends upgrading to the latest Grafana version, and this applies to plugins as well.
Note
Plugins are automatically updated in Grafana Cloud.
