Configure the OpenTelemetry Collector to write metrics into Mimir
When using the
OpenTelemetry Collector, you can write metrics into Mimir via two options: prometheusremotewrite
and otlphttp
We recommend using the prometheusremotewrite
exporter when possible because the remote write ingest path is tested and proven at scale.
Remote Write
For the Remote Write, use the
exporter in the Collector:
In the exporters
section add:
exporters:
prometheusremotewrite:
endpoint: http://<mimir-endpoint>/api/v1/push
And enable it in the service.pipelines
service:
pipelines:
metrics:
receivers: [...]
processors: [...]
exporters: [..., prometheusremotewrite]
If you want to authenticate using basic auth, we recommend the
basicauth
extension:
extensions:
basicauth/prw:
client_auth:
username: username
password: password
exporters:
auth:
authenticator: basicauth/prw
service:
extensions: [basicauth/prw]
pipelines:
metrics:
receivers: [...]
processors: [...]
OTLP
Mimir supports native OTLP over HTTP. To configure the collector to use the OTLP interface, you use the
otlphttp
exporter:
exporters:
otlphttp:
endpoint: http://<mimir-endpoint>/otlp
And enable it in service.pipelines
service:
pipelines:
metrics:
receivers: [...]
processors: [...]
exporters: [..., otlphttp]
basicauth
extension:
extensions:
basicauth/otlp:
client_auth:
username: username
password: password
exporters:
otlphttp:
auth:
authenticator: basicauth/otlp
service:
extensions: [basicauth/otlp]
pipelines:
metrics:
receivers: [...]
processors: [...]
