Menu
HTTP debugging
Things don’t always work as expected. For those cases, enabling the –http-debug option will log HTTP requests and responses to help you debugging the script.
--http-debuglogs the HTTP requests and responses, skipping the body.--http-debug="full"logs the HTTP requests and responses, including the full body.
Example
Given the following script:
import http from "k6/http";
export default function() {
http.get("https://google.com/");
}If we run it using k6 run --http-debug script.js we get output that looks like this:
/\ / \ | |_/ / / /
/ \ | |‾\ \ | (_) |
/ __________ \ |__| \__\ \___/ .io
execution: local
output: -
script: script.js
duration: -, iterations: 1
vus: 1, max: 1
Request: [----------------------------------------------------------] starting
GET / HTTP/1.1
Host: google.com
User-Agent: k6/0.20.0 (https://k6.io/);
Accept-Encoding: gzip
RedirectResponse:
HTTP/2.0 302 Found
Content-Length: 267
Alt-Svc: hq=":443"; ma=2592000; quic=51303432; quic=51303431; quic=51303339; quic=51303335,quic=":443"; ma=2592000; v="42,41,39,35"
Cache-Control: private
Content-Type: text/html; charset=UTF-8
Date: Thu, 22 Mar 2018 13:39:44 GMT
Location: https://www.google.se/?gfe_rd=cr&dcr=0&ei=ILKzWqiODOaxX_LBi5AG
Referrer-Policy: no-referrer
RedirectRequest:
GET /?gfe_rd=cr&dcr=0&ei=ILKzWqiODOaxX_LBi5AG HTTP/1.1
Host: www.google.se
User-Agent: k6/0.19.0 (https://k6.io/);
Referer: https://google.com/
Response:
HTTP/2.0 200 OK
Connection: close
Accept-Ranges: none
Cache-Control: private, max-age=0
Content-Type: text/html; charset=ISO-8859-1
Expires: -1
P3p: CP="This is not a P3P policy! See g.co/p3phelp for more info."
Server: gws
Set-Cookie: 1P_JAR=2018-03-22-13; expires=Sat, 21-Apr-2018 13:39:44 GMT; path=/; domain=.google.se
Set-Cookie: NID=126=asTcm5s3-jMa1-pquG09m9lpUrowy-OtzZ9cUomBuKeJePbvwJAZe5wCtiyLITj9_RrlWLf6DTQ8ufpdB39MCRV-zUpfXAUw8XUVMWtgdU1gbtnQ9rssin56333g9Hyo; expires=Fri, 21-Sep-2018 13:39:44 GMT; path=/; domain=.google.se; HttpOnly
Vary: Accept-Encoding
X-Frame-Options: SAMEORIGIN
X-Xss-Protection: 1; mode=block
