JavaScript compatibility mode
You can write k6 scripts in various ECMAScript versions:
- ES6+ JavaScript with ES modules (ESM).
- ES6+ JavaScript with CommonJS modules.
k6 supports both module types and most ES6+ features in all k6 execution modes: local, distributed, and cloud.
To enable ES module support, k6 uses Babel internally to transform ESM to CommonJS. The process is as follows:
Some users prefer to bundle their test code outside k6. For this reason, k6 offers two JavaScript compatibility modes:
- Extended mode: The default option, supporting ESM and most ES6+ features.
- Base mode: Limited to CommonJS, excluding the Babel step.
When running tests, you can change the mode by using the --compatibility-mode option:
Extended mode
By default, k6 uses the --compatibility-mode=extended mode:
$ k6 run script.jsAs illustrated in the previous diagram, if k6 detects unsupported ES+ features while parsing the test script, it then transforms the script with Babel to polyfill the unsupported features.
Currently, the k6 Babel transformation only adds ESM support and sets global (node’s global variable) with the value of globalThis.
Base mode
$ k6 run --compatibility-mode=base script.js$ K6_COMPATIBILITY_MODE=base k6 run script.jsThe base mode omits the Babel transformation step, supporting only ES5.1+ code. You may want to enable this mode if your scripts are already written using only ES5.1 features or were previously transformed by Babel.
Generally, this mode is not recommended as it offers minor benefits in reducing startup time.
CommonJS Example
const http = require('k6/http');
const k6 = require('k6');
module.exports.options = {
vus: 10,
duration: '30s',
module.exports.default = function () {
http.get('http://test.k6.io');
k6.sleep(1);
};⚠️ About require()
Note that
require()is a custom k6 implementation of module loading, which doesn’t behave in the same way as the require() call in Node.js. Specifically, it only handles loading of built-in k6 modules, scripts on the local filesystem, and remote scripts over HTTP(S), but it does not support the Node.js module resolution algorithm.
Bundling with Babel outside of k6
The examples below demonstrate the use of Babel with bundlers like Webpack and Rollup:
- k6-template-es6: Template using Webpack and Babel to bundle k6 tests.
- k6-rollup-example: Example using Rollup and Babel to bundle a testing project.
Read more
- Native ESM support: GitHub issue for native ESM support in k6. This feature aims to eliminate the Babel transformation step within k6.
- Running large tests: Optimize k6 for better performance.
- k6 Modules: Different options to import modules in k6.
- k6 Archive Command: The
k6 archivecommand bundles all k6 test dependencies into atarfile, which can then be used for execution. It may also reduce the execution startup time.
